In this section you will learn how to:
You will run all the commands shown below on your Raspberry Pi 5 running Raspberry Pi OS (64-bit).
In your Raspberry Pi Terminal, install uv:
curl -LsSf https://astral.sh/uv/install.sh | sh
uv is a Rust-based, next-generation Python package manager that replaces tools like pip, virtualenv, and Poetry. It delivers 10×–100× faster installs along with built-in virtual environments, lockfile support, and full Python ecosystem compatibility.
After the script finishes, restart your terminal so that the uv command is on your PATH.
mkdir mcp
cd mcp
uv:
uv init
This command adds:
uv pip install fastmcp==2.2.10
uv add requests
server.py:
touch server.py
import subprocess, re
from mcp.server.fastmcp import FastMCP
mcp = FastMCP("RaspberryPi MCP Server")
@mcp.tool()
def read_temp():
Description: Raspberry Pi's CPU core temperature
Return: Temperature in °C (float)
print(f"[debug-server] read_temp()")
out = subprocess.check_output(["vcgencmd", "measure_temp"]).decode()
temp_c = float(re.search(r"[-\d.]+", out).group())
return temp_c
@mcp.tool()
def get_current_weather(city: str) -> str:
Description: Get Current Weather data in the {city}
Args:
city: Name of the city
Return: Current weather data of the city
print(f"[debug-server] get_current_weather({city})")
endpoint = "https://wttr.in"
response = requests.get(f"{endpoint}/{city}")
return response.text
if __name__ == "__main__":
mcp.run(transport="sse")
Run the Python script to deploy the MCP server:
uv run server.py
By default, FastMCP listens on port 8000 and exposes your registered tools over HTTP using Server-Sent Events (SSE).
The output should look like:
INFO: Started server process [2666]
INFO: Waiting for application startup.
INFO: Application startup complete.
INFO: Uvicorn running on http://0.0.0.0:8000 (Press CTRL+C to quit)
You will now use ngrok to expose your locally running MCP server to the public internet over HTTPS.
curl -sSL https://ngrok-agent.s3.amazonaws.com/ngrok.asc \
| sudo tee /etc/apt/trusted.gpg.d/ngrok.asc >/dev/null \
&& echo "deb https://ngrok-agent.s3.amazonaws.com buster main" \
| sudo tee /etc/apt/sources.list.d/ngrok.list \
&& sudo apt update \
&& sudo apt install ngrok
The ngrok agent authenticates with an authtoken. You will need to authenticate your account with the token which is available on the ngrok dashboard .
ngrok config add-authtoken <YOUR_NGROK_AUTHTOKEN>
Replace YOUR_NGROK_AUTHTOKEN with your token from the ngrok dashboard.
ngrok http 8000
https://abcd1234.ngrok-free.app). You’ll use this endpoint to connect external tools or agents to your MCP server. Keep this URL available for the next steps in your workflow.You now have a working FastMCP server on your Raspberry Pi 5. It includes tools for reading CPU temperature and retrieving weather data, and it’s accessible over the internet via a public HTTPS endpoint using ngrok. This sets the stage for integration with LLM agents or other external tools.
