In this section, you’ll learn how to set up an AI Agent on your development machine. You will then connect your MCP server running on the Raspberry Pi 5 to it.
These commands were tested on a Linux Arm development machine.
Create an AI agent and point it at your Pi’s MCP Server
  1. Install uv on your development machine:
curl -LsSf https://astral.sh/uv/install.sh | sh
  1. Create a directory for the Agent:
mkdir mcp-agent && cd mcp-agent
  1. Set up the directory to use uv:
uv init
This command adds:
  • .venv/ (auto-created virtual environment).
  • pyproject.toml (project metadata and dependencies).
  • .python-version (pinned interpreter).
  • README.md, .gitignore, and a sample main.py.
  1. Install OpenAI Agents SDK + dotenv:
uv add openai-agents python-dotenv
  1. Create a .env file to securely store your OpenAI API key:
echo -n "OPENAI_API_KEY=<YOUR_OPENAI_API_KEY>" > .env
Write the Python script for the Agent Client
Use a file editor of your choice and replace the content of the sample main.py with the content shown below:
import asyncio, os
from dotenv import load_dotenv
# disable Agents SDK tracing for cleaner output
os.environ["OPENAI_AGENTS_DISABLE_TRACING"] = "1"
load_dotenv()
from agents import Agent, Runner, set_default_openai_key
from agents.mcp import MCPServerSse
from agents.model_settings import ModelSettings
async def run(mcp_server: list[MCPServerSse]):
    set_default_openai_key(os.getenv("OPENAI_API_KEY"))
    agent = Agent(
        model="gpt-4.1-2025-04-14",
        name="Assistant",
        instructions="Use the tools to answer the user's query",
        mcp_servers=mcp_server,
        model_settings=ModelSettings(tool_choice="required"),
    for message in ["What is the CPU temperature?", "How is the weather in Cambridge?"]:
        print(f"Running: {message}")
        result = await Runner.run(starting_agent=agent, input=message)
        print(f"Response: {result.final_output}")
async def main():
    # replace URL with your ngrok-generated endpoint
    url = "<YOUR_NGROK_URL>/sse"
    async with MCPServerSse(
        name="RPI5 MCP Server",
        params={"url": url},
        client_session_timeout_seconds=60,
    ) as server1:
        await run([server1])
if __name__ == "__main__":
    asyncio.run(main())
Execute the Agent
You’re now ready to run the AI Agent and test its connection to your running MCP server on the Raspberry Pi 5.
Run the main.py Python script:
uv run main.py
The output should look something like this:
        Running: What is the CPU temperature?
Response: The current CPU temperature is 48.8°C.
Running: How is the weather in Cambridge?
The weather in Cambridge is currently partly cloudy with a temperature of around 10°C. The wind is blowing at approximately 17 km/h. Visibility is good at 10 km, and there is no precipitation expected at the moment. The weather should be pleasant throughout the day with temperatures rising to about 15°C by midday.
Congratulations! Your local AI Agent just called the MCP server on your Raspberry Pi and fetched the CPU temperature and the weather information.
This lightweight protocol isn’t just a game-changer for LLM developers - it also empowers IoT engineers to transform real-world data streams and give AI direct, reliable control over any connected device.
Next steps
  • Expand Your Toolset
    • Write additional @mcp.tool() functions for Pi peripherals (such as GPIO pins, camera, and I²C sensors).
    • Combine multiple MCP servers (for example, filesystem, web-scraper, and vector-store memory) for richer context.
  • Integrate with IoT Platforms
    • Hook into Home Assistant or Node-RED through MCP.
    • Trigger real-world actions (for example, turn on LEDs, read environmental sensors, and control relays).
Section summary
You’ve now built and run an AI agent on your development machine that connects to an MCP server on your Raspberry Pi 5. Your agent can now interact with real-world data sources in real time - a complete edge-to-cloud loop powered by OpenAI’s Agent SDK and the MCP protocol.
