Explore related resources
Give feedback
AI-assisted
Close
Where do I run the MCP server, and where do I run the AI agent?
Run the MCP server on Raspberry Pi 5. Run the AI agent on your development machine and connect it to the Pi over your network or through the ngrok tunnel.
Do I need `uv` installed on both my Raspberry Pi and my development machine?
Yes. Install uv on Raspberry Pi to set up the MCP server, and install it on your development machine to initialize and run the agent project.
After I run `uv init` for the agent, what files should appear?
uv init creates a .venv virtual environment and a pyproject.toml file in the project directory. Both files indicate that the project environment is ready.
How do I point the agent at the MCP server on my Raspberry Pi?
Add the MCP server address to the agent configuration, using either the ngrok HTTPS forwarding URL or the Pi’s reachable network address. A correct endpoint lets the agent start without connection errors.
How do I know the CPU temperature and weather tools are actually being used?
Prompt the agent to report Raspberry Pi’s CPU temperature or look up weather data. The response includes the requested values. If it doesn’t, verify that the server is running and the connection details match.
