Measure the thread sweep directly
You’re now ready to make decisions based on the decode and prefill diagnosis that you performed.
The diagnosis picks the best thread count for each model. To see the whole sweep, run llama-bench directly on one model:
cd $HOME/llama.cpp
./build/bin/llama-bench -m $HOME/models/qwen2.5-0.5b-instruct-q4_0.gguf \
    -t 1,2,3,4 -p 512 -n 128 -r 5 -o md
The output is similar to:
        | model                          |       size |     params | backend    | threads |            test |                  t/s |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       1 |           pp512 |         93.49 ± 0.20 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       1 |           tg128 |         32.42 ± 0.14 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       2 |           pp512 |        173.68 ± 0.08 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       2 |           tg128 |         33.84 ± 0.05 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       3 |           pp512 |        233.22 ± 0.94 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       3 |           tg128 |         29.37 ± 0.05 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       4 |           pp512 |        289.92 ± 0.11 |
| qwen2 1B Q4_0                  | 403.20 MiB |   630.17 M | CPU        |       4 |           tg128 |         27.28 ± 0.02 |
build: 836d571 (1)
Each row of the table is one test at one thread count:
  • pp512 is prompt processing of a 512-token prompt.
  • tg128 is token generation of 128 tokens.
  • t/s is tokens per second, with the standard deviation over five repetitions.
The example measurements were made on a Raspberry Pi 5 with 2 GB of RAM. The build used llama.cpp commit 836d571, GCC 12.2.0, and the default Release flags. The board used the ondemand governor. The get_throttled command reported throttled=0x0 before and after the sweep. Threads weren’t pinned to cores.
Find the decode knee
Look at the tg128 rows as threads increase. On a memory-bound system, decode stops improving after a small number of threads. Extra threads wait on the same memory, and decode performance can fall as you add more.
The decode knee is at two threads. Using four threads reduces decode performance by 19.4%.
Now look at the pp512 rows. Prefill keeps rising up to four threads, because it’s compute-bound.
Prefill scales well with more threads, reaching 3.10 times the one-thread result when using four threads.
You can draw the following conclusions from this:
  • For workloads with short prompts and long answers, such as a chat, set -t to the decode knee.
  • For workloads with long prompts and short answers, such as summarization, use all cores.
  • Always set -t explicitly. The default isn’t chosen for your workload.
Predict the effect of a smaller model
Because decode is memory-bound, the ratio of model sizes predicts the ratio of decode speeds.
The WHAT TO CHANGE section of the diagnosis compares two of your models:
        Measured here: qwen2.5-0.5b-instruct-q4_0 is 2.68x smaller than qwen2.5-1.5b-instruct-q4_0 and decodes 2.75x faster.
If the size ratio and the speed ratio are close, the bandwidth equation holds on your system.
You can then estimate the decode speed of any dense model before you download it:
expected tokens/s  =  fitted bandwidth  /  bytes per token
For example, consider the fitted bandwidth of 11.82 GB/s measured on the Raspberry Pi 5. On a Pi with that bandwidth, a model that reads 2 GB per token decodes at about 6 tokens/s.
Note
This estimate is a short-context result. As the key-value (KV) cache grows during a long conversation, decode reads more than the weights. It slows down beyond what the equation predicts. Use the --depth option of llama-roofline run to measure decode with tokens already in the context.
What you’ve accomplished
You’ve now chosen thread counts for decode and prefill from measurements. You’ve learned to predict decode speed from model size and fitted bandwidth. You know why an Arm system generates tokens at a given rate, and what change will make it faster.
Run the same commands on other Arm Linux systems to evaluate their ceiling, fitted bandwidth, and decode knee.
