Prepare the system for measurement
After setting up llama-roofline and downloading three models, you’re ready to measure memory bandwidth.
Background load lowers measured bandwidth and makes every result that depends on it wrong.
Before you measure bandwidth, complete the following steps:
  1. Close other applications and stop any running benchmarks.
  2. Check that the board is idle and has free memory:
    uptime
    free -m
    The load average should be close to zero. Ensure that the available column is larger than the largest model file that you’ll run. The largest file is 1,066 MB.
  3. On a Raspberry Pi 5, check that the board isn’t throttling:
    vcgencmd measure_temp
    vcgencmd get_throttled
    Ensure that the output of get_throttled is throttled=0x0. If it isn’t, fit the active cooler and wait for the board to cool down.
  4. Check the CPU frequency governor:
    cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    The outputs were measured with the ondemand governor, the Raspberry Pi OS default. Record the governor with your results, because changing it changes the results.
Measure the sustained read bandwidth
Run the bandwidth measurement on its own:
llama-roofline membw
The tool runs read-only kernels (sum, max and dot) at several thread counts over a working set much larger than the caches. It repeats each one and reports the best sustained read rate as the ceiling.
The tool also prints a copy kernel for reference. However, it doesn’t use the kernel for the ceiling because a copy writes as well as reads.
The output is similar to:
        machine: Raspberry Pi 5 Model B Rev 1.0 (4 logical cores, 2.1 GB RAM)
    1 threads   sum   13.7   max   13.8   dot   12.2   copy   10.3  GB/s
    2 threads   sum   12.7   max   12.6   dot   11.4   copy    8.7  GB/s
    4 threads   sum   10.5   max   10.7   dot    8.8   copy    6.5  GB/s
sustained read ceiling: 13.78 GB/s (max kernel @ 1 threads, 263 MB working set)
this is a measured lower bound on true peak; pass it to `run` with --peak-bw 13.78
wrote /home/manu/lp_capture/20261003_2358/membw_1.json
One thread already reaches the highest read rate. Adding threads lowers it. This is the first sign that decode, which streams the weights from memory, doesn’t need all four cores.
Note
The ceiling is a measured lower bound on the true peak. llama.cpp hand-written kernels can stream faster than the Python kernels that the tool uses. If decode exceeds the measured ceiling, llama-roofline warns you and treats the percentages as lower bounds.
If you already have a trusted STREAM result for your system, pass it with --peak-bw to skip this step.
Check that the measurement is repeatable
Run llama-roofline membw two more times and compare the sustained read ceiling lines. On an idle board, the values agree closely. On the Raspberry Pi 5, the three runs reported 13.78, 13.78 and 13.77 GB/s.
If your runs differ by more than 5 percent, something else is using memory bandwidth. Find and stop it before you continue, because you’ll compare every later result with this ceiling.
You’ve measured how many bytes per second your Arm system can read from DRAM. This is the roof that decode runs into.
Next, you’ll measure decode and prefill, and compare them with this ceiling.
