Give feedback
AI-assisted
Close
How do I confirm my system is 64-bit Arm and see which CPU features are present?
Run uname -m and grep -m1 Features /proc/cpuinfo. Look for aarch64 and flags such as asimd (Neon) and asimddp (DotProd). On the Raspberry Pi 5’s Cortex-A76, llama.cpp detects DotProd at build time and uses it for quantized kernels.
What should I check before measuring memory bandwidth?
Close other applications and ensure your system is idle. Use uptime and free -m to confirm low load and that available memory exceeds the largest model file (1,066 MB). Background load lowers measured bandwidth and distorts results that depend on it.
How do I see how many bytes per token a model reads during decode?
Run llama-roofline inspect on the GGUF file. Check the per token line in its report to see the estimated model data read per generated token, in megabytes.
How do I know whether decode is memory-bound after inspection and measurement?
Multiply the bytes per token reported by llama-roofline inspect by your measured decode tokens per second. Compare that achieved bandwidth with the measured ceiling, or use the percentage of the ceiling listed in the report. If it approaches the ceiling, memory bandwidth limits decode performance, so adding threads might not help.
What result should I expect from the llama-bench thread sweep, and how do I pick a thread count?
Read the llama-bench table, which reports threads and tokens per second (t/s). Choose the best thread count separately for tg128 decode and pp512 prefill. Decode can saturate quickly when memory-bound, while prefill can benefit from more threads.
