You previously saw that demotions are not detected in C and only in a few cases in C++.
To learn more about demotions, consider the small C++ program below.
Use a text editor to copy the code to a text file named demotiontest.cpp:
#include <cmath>
#include <cstdio>
#include <cstdint>
int main() {
double w = 1.0e50;
printf("w = %f\n", w);
float y = w;
float z{w};
printf("y = %f\n", y);
printf("z = %f\n", z);
int16_t a = -16380;
int32_t b = a*1000;
int64_t c = b*1000;
int16_t d1 = c*2;
int16_t d2{c*2};
printf("a = %d, b = %d, c = %ld, d1 = %d, d2 = %d\n", a, b, c, d1, d2);
int32_t e1 =w;
int32_t e2{w};
printf("e1 = %d, e2 = %d\n", e1, e2);
Compile the example:
g++ demotiontest.cpp -o demotiontest
You will most likely get the following warnings but the program will compile successfully:
demotiontest.cpp: In function ‘int main()’:
demotiontest.cpp:9:13: warning: narrowing conversion of ‘w’ from ‘double’ to ‘float’ [-Wnarrowing]
9 | float z{w};
demotiontest.cpp:18:17: warning: narrowing conversion of ‘(c * 2)’ from ‘int64_t’ {aka ‘long int’} to ‘int16_t’ {aka ‘short int’} [-Wnarrowing]
18 | int16_t d2{c*2};
demotiontest.cpp:22:16: warning: narrowing conversion of ‘w’ from ‘double’ to ‘int32_t’ {aka ‘int’} [-Wnarrowing]
22 | int32_t e2{w};
Now run the program:
./demotiontest
The output is:
w = 100000000000000007629769841091887003294964970946560.000000
y = inf
z = inf
a = -16380, b = -16380000, c = 799869184, d1 = 4608, d2 = 4608
e1 = 2147483647, e2 = 2147483647
Obviously w is a huge value and it does not fit in a float (remember that the largest positive float is 3.4e+38), but the compiler only complains about z which uses bracket initialization and not y which uses assignment.
Similarly d1, with type int16_t, uses assignment and does not generate a warning but d2, also an int16_t, uses bracket initialization and triggers a compiler warning.
The same happens with the demotion/conversion of the double w to the int32_t variables e1, e2.
This means that some demotions/conversions that happen through assignment can pass the compiler without a warning, leading to wrong values and difficult to track bugs.
In general, demotions are risky and you should always take a second look when a demotion takes place. When using C++, try to use bracket initialization to trigger compiler warnings.
