A closer look at implicit conversions
The example below explains more about implicit conversions.
The code is meant to calculate the golden ratio number 1.618033988749894… using 2 consecutive Fibonacci numbers, as φ[N] = F[N]/F[N-1] and Φ = Φ[Ν] as N -> inf.
Use a text editor to save the C program in a file named golden_ratio.c:
#include <math.h>
#include <stdio.h>
#include <stdint.h>
#define MAX 50
static int fibonacci[MAX];
void calculate_fibonacci(size_t N) {
    fibonacci[0] = 0;
    fibonacci[1] = 1;
    for (int i = 2; i < N; ++i) {
        fibonacci[i] = fibonacci[i-2] + fibonacci[i-1];
void print_fibonacci(size_t N) {
    for (int i = 0; i < N; ++i) {
        printf("%d ", fibonacci[i]);
    printf("\n");
float golden_ratio(int N) {
    float golden_ratio = fibonacci[N]/fibonacci[N-1];
    return golden_ratio;
int main() {
    calculate_fibonacci(50);
    print_fibonacci(50);
    for (int i = 2; i < MAX; i++) {
        float result = golden_ratio(i);
        printf("Golden ratio using N: %d Fibonacci numbers: %f\n", i, result);
    return 0;
Compile and run the program:
gcc -O3 golden_ratio.c -o golden_ratio
./golden_ratio
The output is:
        0 1 1 2 3 5 8 13 21 34 55 89 144 233 377 610 987 1597 2584 4181 6765 10946 17711 28657 46368 75025 121393 196418 317811 514229 832040 1346269 2178309 3524578 5702887 9227465 14930352 24157817 39088169 63245986 102334155 165580141 267914296 433494437 701408733 1134903170 1836311903 -1323752223 512559680 -811192543
Golden ratio using N: 2 Fibonacci numbers: 1.000000
Golden ratio using N: 3 Fibonacci numbers: 2.000000
Golden ratio using N: 4 Fibonacci numbers: 1.000000
Golden ratio using N: 5 Fibonacci numbers: 1.000000
Golden ratio using N: 6 Fibonacci numbers: 1.000000
Golden ratio using N: 7 Fibonacci numbers: 1.000000
Golden ratio using N: 8 Fibonacci numbers: 1.000000
Golden ratio using N: 9 Fibonacci numbers: 1.000000
Golden ratio using N: 10 Fibonacci numbers: 1.000000
Golden ratio using N: 40 Fibonacci numbers: 1.000000
Golden ratio using N: 41 Fibonacci numbers: 1.000000
Golden ratio using N: 42 Fibonacci numbers: 1.000000
Golden ratio using N: 43 Fibonacci numbers: 1.000000
Golden ratio using N: 44 Fibonacci numbers: 1.000000
Golden ratio using N: 45 Fibonacci numbers: 1.000000
You will immediately notice that the results are unexpected because the golden_ratio() function is incorrect.
All results will be either 1.0 or 2.0. This is because the division is done between the integers and then converted to floating-point. This is a frequent problem which is usually easy to find and fix. However, there are cases where it’s part of complex arithmetic expressions and easy to miss. Unfortunately, the compiler does not generate a warning.
You can fix the problem and demonstrate a different problem by splitting the calculation to avoid the previous integer division:
	float golden_ratio = fibonacci[N];
    golden_ratio /= fibonacci[N-1];
Compile and run the program again:
./golden_ratio
The output is:
Golden ratio using N: 2 Fibonacci numbers: 1.00000000000000
Golden ratio using N: 3 Fibonacci numbers: 2.00000000000000
Golden ratio using N: 4 Fibonacci numbers: 1.50000000000000
Golden ratio using N: 5 Fibonacci numbers: 1.66666662693024
Golden ratio using N: 6 Fibonacci numbers: 1.60000002384186
Golden ratio using N: 7 Fibonacci numbers: 1.62500000000000
Golden ratio using N: 44 Fibonacci numbers: 1.61803388595581
Golden ratio using N: 45 Fibonacci numbers: 1.61803400516510
Golden ratio using N: 46 Fibonacci numbers: 1.61803400516510
Golden ratio using N: 47 Fibonacci numbers: -0.72087544202805
Golden ratio using N: 48 Fibonacci numbers: -0.38720214366913
Golden ratio using N: 49 Fibonacci numbers: -1.58263039588928
You will notice two things:
First, the 32-bit int is not large enough to hold Fibonacci numbers for N >= 47. This is easily fixed by changing to int64_t.
Next, you can also change float to double. This will also give increased precision in the calculations.
However, this is not the actual problem.
Look at the assembly code of golden_ratio():
golden_ratio:
        sub     w2, w0, #1
        adrp    x1, .LANCHOR0
        add     x1, x1, :lo12:.LANCHOR0
        ldr     s2, [x1, w0, sxtw 2]
        ldr     s1, [x1, w2, sxtw 2]
        scvtf   s2, s2
        scvtf   s0, s1
        fdiv    s0, s2, s0
        ret
You can see that the scvtf instruction is executed twice, which converts from integer to floating point, so that the quantities can be divided using floating point with the fdiv instruction. The scvtf instruction has up to 6 CPU cycles latency on the Neoverse N1 processor and 3 cycles on the Neoverse N2. Imagine a complicated expression involving many similar implicit conversions, executed millions or billions of times. It would definitely underperform.
This example is easy to fix if you just convert the fibonacci array to float or double:
static float fibonacci[MAX];
and rewrite the golden_ratio() function as single line division:
    float golden_ratio = fibonacci[N] / fibonacci[N-1];
The assembly output does not contain any scvtf instructions:
golden_ratio:
        sub     w2, w0, #1
        adrp    x1, .LANCHOR0
        ldr     s1, [x1, w0, sxtw 2]
        ldr     s0, [x1, w2, sxtw 2]
        fdiv    s0, s1, s0
        ret
Compile the updated program and run it:
./golden_ratio
The output is now:
1836311903 2971215073 4807526976 7778742049
Golden ratio using N: 43 Fibonacci numbers: 1.61803400516510
Golden ratio using N: 44 Fibonacci numbers: 1.61803400516510
Golden ratio using N: 47 Fibonacci numbers: 1.61803400516510
Golden ratio using N: 48 Fibonacci numbers: 1.61803400516510
Golden ratio using N: 49 Fibonacci numbers: 1.61803400516510
Not all problems are as easy to fix. If your use case involves numbers that are too big to fit in int64_t or even in double, incorrect results will occur.
You can change MAX to 100 and see incorrect results as the loop approaches 100.
In such cases another method would have to be used, possibly an arbitrary precision data type in a library created to handle large numbers.
Implicit conversions can have a significant impact in performance, especially in loops involving complex mathematical expressions.
