What you've learned
You should now know how to:
  • Learn how to identify and fix potential problems in integer/float conversions in C/C++ on Arm
Knowledge Check
Finish the statement: Mixing integer and floating-point types in arithmetic expressions in C
Which data type stores the most floating point numbers using the largest range in the same storage, when precision is not the most important requirement?
Type demotion problems are detected by the compiler in C/C++.
