Build a CI/CD pipeline using GitLab-hosted Arm runners
Build and use GitLab-hosted Arm runners for CI/CD
Create a GitLab project
Build and configure your Arm64 CI/CD pipeline
Run pipeline and verify results
Use the Docker executor to run containerized builds on GitLab‑hosted runners. This path configures jobs to run on arm64 by adding the Arm64 runner tag in
.gitlab-ci.yml.Add the Arm64 runner tag to the job’s tags section in
.gitlab-ci.yml. Jobs that include this tag are scheduled on GitLab‑hosted arm64 runners.Open the job log and review the
lscpu output. The reported architecture should indicate Arm64, confirming that the job executed on the intended runner.You should see successful build and push stages, with logs showing the C program compilation and container image creation. The new image and tag appear in the project’s GitLab Container Registry.
Verify that the push stage finished without errors in the job log. Then open the project’s Container Registry page and confirm the expected image tag is listed.
