Function multiversioning is compatible with Arm streaming mode as long as the same calling convention is used across all function versions.
Use a text editor to create a file named streaming.c with the code below:
__attribute__((target_clones("sve", "simd")))
void ok_arm_streaming(void) __arm_streaming {}
__arm_locally_streaming __attribute__((target_version("sme2")))
__attribute__((target_version("default")))
void ok_arm_streaming_compatible(void) __arm_streaming_compatible {}
__arm_locally_streaming __attribute__((target_clones("sve", "simd")))
void ok_no_streaming(void) {}
void bad_mixed_streaming(void) {}
void bad_mixed_streaming(void) __arm_streaming {} // expected-error: declaration has a different calling convention
void bad_mixed_streaming(void) __arm_streaming_compatible {} // expected-error: declaration has a different calling convention
__arm_locally_streaming __attribute__((target_version("dotprod")))
void n_caller(void) {
ok_arm_streaming();
ok_arm_streaming_compatible();
ok_no_streaming();
bad_mixed_streaming();
void s_caller(void) __arm_streaming {
ok_arm_streaming();
ok_no_streaming();
void sc_caller(void) __arm_streaming_compatible {
ok_arm_streaming();
ok_no_streaming();
To compile with Clang, run:
clang --target=aarch64-linux-gnu -march=armv8-a+sme --rtlib=compiler-rt -c streaming.c
