One cause of different outputs between x86 and Arm stems from the order of instructions and how errors are propagated. As a hypothetical example, an Arm system may decide to reorder the instructions that each have a different rounding error so that subtle changes are observed.
It is possible that two functions that are mathematically equivalent will propagate errors differently on a computer.
Functions f1
and f2
are mathematically equivalent. You would expect them to return the same value given the same input.
If the input is a very small number, 1e-8
, the error is different due to the loss in precision caused by different operations. Specifically, f2
avoids subtracting nearly equal numbers for clarity. For a full description look into the topic of
numerical stability
Use an editor to copy and paste the C++ code below into a file named error-propagation.cpp
#include <stdio.h>
#include <math.h>
// Function 1: Computes sqrt(1 + x) - 1 using the naive approach
float f1(float x) {
return sqrtf(1 + x) - 1;
// Function 2: Computes the same value using an algebraically equivalent transformation
// This version is numerically more stable
float f2(float x) {
return x / (sqrtf(1 + x) + 1);
int main() {
float x = 1e-8; // A small value that causes floating-point precision issues
float result1 = f1(x);
float result2 = f2(x);
// Theoretically, result1 and result2 should be the same
float difference = result1 - result2;
// Multiply by a large number to amplify the error
float final_result = 100000000.0f * difference + 0.0001f;
// Print the results
printf("f1(%e) = %.10f\n", x, result1);
printf("f2(%e) = %.10f\n", x, result2);
printf("Difference (f1 - f2) = %.10e\n", difference);
printf("Final result after magnification: %.10f\n", final_result);
return 0;
Compile the code on both x86 and Arm with the following command:
g++ -g error-propagation.cpp -o error-propagation
Running the two binaries shows that the second function, f2
, has a small rounding error on both architectures. Additionally, there is a further rounding difference when run on x86 compared to Arm.
Running on x86:
f1(1.000000e-08) = 0.0000000000
f2(1.000000e-08) = 0.0000000050
Difference (f1 - f2) = -4.9999999696e-09
Final result after magnification: -0.4999000132
Running on Arm:
Final result after magnification: -0.4998999834
