Why pad matrix B
Although unaligned vector loads from memory are supported, they have drawbacks. Vectors can straddle cache lines. Loop code is complicated by the need to adjust the pointer register at the end of every row.
Consider a matrix with a column count that isn’t an exact multiple of the ZA tile column count for a given data element size. For such a matrix, padding the data might be a better solution. Padding results in cleaner loop code and fully sequential memory access.
Inspect the padded result
The following visualization depicts the padded matrix B. To keep this Learning Path open while exploring, open the Pad B visualization in a separate browser tab. Move the tab to a separate window to view the visualization and Learning Path side by side.
Follow the padding algorithm:
StageNumber of stepsOperation
Load the first row3Load the first row of Input Matrix B into ZA0.
Load the second row3Load the second row of Input Matrix B into ZA0–ZA1, with zero padding on the final load.
Load the remaining rows6Load the third and fourth rows into ZA1–ZA2.
Store the padded data12Write the rows of ZA0–ZA2 into Output Padded Data.
A predicate register controls which columns are active and limits the third block of each row to load just two columns. This leaves the other columns zero-padded. The padded data store happens with all columns active, so zero padding is copied verbatim to the output buffer.
Important
Scalable vector length can vary between devices. This visualization zero-pads the data for the tile size of the device. Running the same code on a different device with a different scalable vector length can result in a different output data structure. Specifically, for larger scalable vector lengths, there’s likely to be more padding. However, it depends on the number of columns.
The fact that different devices can produce different output data structures isn’t a problem. Each device generates a data structure for its own ZA tile width. Each device later uses that data structure with its ZA tiles, to compose input vectors for the Outer Product operation. Although the data structure can vary between devices, the Outer Product results are the same across all devices.
You’ve seen how the visualization pads an input matrix with zeros so that it aligns with the tile width of the device. You’ve learned that this padded structure can vary on devices with a different scalable vector length. However, the final matrix multiplication result is identical on all devices.
Next, you’ll view a visualization that starts with packed A and padded B, then multiplies them into an output matrix.
