Give feedback
AI-assisted
Close
Which extensions should I enable to load the artifacts used here?
Enable the ExecuTorch extension to open .pte and .etrecord files and add .etdp profiling overlays. Enable the TOSA adapter for .tosa files and the VGF adapter for .vgf files. By running all three, you can switch between formats in one session.
How do I recognize delegate regions and fragmentation in a PTE?
Inspect the graph for a single contiguous delegate region, multiple smaller delegate regions, or nodes that remain outside the delegate. Use this view to see how much of the model is delegated and where non-delegated work occurs.
What result should I expect when opening the Cortex-M .pte example?
The deployment graph renders in the browser with expandable nodes and metadata. Seeing the graph confirms the installation and that the ExecuTorch extension is active.
How do I compare portable and XNNPACK PTEs for Cortex-A CPU paths?
Open both PTE files and examine operator nodes and backend-specific changes. Look for differences in how operators are implemented and where execution paths differ from portable kernels.
How do I connect runtime data to the exported graph?
Open the matching .etrecord file and its .etdp profiling data with the ExecuTorch extension enabled. Model Explorer overlays align profiling events with matching graph nodes so you can correlate structure with runtime behavior. Delegate-call timings aren’t included.
