View ExecuTorch runtime profiling data
PTE, TOSA, and VGF views help you learn what was exported, lowered, compiled, converted, or packaged.
Runtime profiling answers a different set of questions. With runtime profiling, you can learn what happened when the artifact ran on a specific runtime, runner, target hardware, and tracing configuration.
You’ll use the ExecuTorch extension for Model Explorer to view profiling data overlaid onto the model graph. The extension reads ETRecord and ETDump files to connect graph nodes to measured runtime behavior.
ETRecord and ETDump
ETRecord provides the export-time graph context. It preserves graph, operator, debug handle, and delegate partition metadata, allowing runtime measurements to map back to graph nodes.
ETDump contains runtime profiling data captured while the model executes with ExecuTorch event tracing enabled. The Model Explorer ETDump data provider presents aggregate timing measurements as overlays on graph nodes. For the XNNPACK and Ethos-U artifacts in this Learning Path, events inside delegate calls don’t contain the information needed to map timings to graph nodes, so Model Explorer doesn’t display their timings. Use ExecuTorch Inspector to view aggregate delegate timings from the matching ETRecord and ETDump.
Use the two artifacts together:
ArtifactLayer inspectedWhat it adds
.etrecordExport-time graph contextGraph structure, debug handles, operator names, and delegate partitions
.etdpRuntime profiling dataAggregate timing data for events that map to graph nodes
ETRecord and ETDump are created at different points:
  • Generate the ETRecord when you export or lower the model.
  • Generate the ETDump when you run the exported .pte program with event tracing enabled.
  • Analyze them together with the ExecuTorch Inspector, or load them together in Model Explorer with the combined ExecuTorch extension.
For generation instructions, see the ExecuTorch ETRecord documentation , and ExecuTorch ETDump documentation .
Inspect a portable kernel CPU profile
Open the portable CPU ETRecord for GPT-2:
        ml-model-artifacts/etrecord/gpt2_portable.etrecord
In Model Explorer, select Add per-node data, choose the ETDump profiling overlay, and load:
        ml-model-artifacts/etdump/gpt2_portable.etdp
Always use an ETDump from the same export as the ETRecord. Profiling data from a different export can map to the wrong nodes.
Inspect the graph and profiling overlay, then look for the following:
  • No delegate partitions
  • Timing data on concrete native-call events
  • Repeated operators that dominate the profile
  • How the runtime view compares with the portable .pte view that you inspected
Image Alt Text:Model Explorer showing the portable GPT-2 ETRecord with Runtime Event Count and Runtime Total timing overlays. The node table contains mapped values for native-call events, and the graph has no delegate region.Portable GPT-2 runtime profile
This portable CPU ETDump contains 1,181 events: two setup events and 1,179 execution events. In this captured run, Method::execute took about 17,761 ms. The provider excludes this wrapper event from the overlay and maps native-call timings to graph nodes. Repeated aten.addmm operations form the main aggregate hotspot, followed by the final matrix multiplication. These timings describe the system used to capture the supplied ETDump; timings on another system will differ.
What you’ve learned
ETRecord and ETDump add runtime context to static graphs. Model Explorer shows timings for profiling events that map to graph nodes.
You can now explore deeper workflows for generating, running, profiling, and optimizing your own models with Model Explorer.
