Launch Model Explorer
Launch Model Explorer with all the extensions that you’ll use. The combined ExecuTorch extension opens .pte and .etrecord files and adds .etdp profiling data. The separate TOSA and VGF extensions open .tosa and .vgf files.
Launching Model Explorer opens a webpage in your browser.
python -m model_explorer --extensions=executorch_extension_model_explorer,tosa_adapter_model_explorer,vgf_adapter_model_explorer
Press Ctrl+C to stop Model Explorer.
Note
If you’re interested in a specific model format or a particular target, skip to the appropriate section.
Inspect the Cortex-M PTE
You’ll start with a .pte generated for the Cortex-M backend. This .pte was generated for the MobileNetV2 model, a typical Convolutional Neural Network (CNN) used in embedded ML.
The ExecuTorch Cortex-M backend prepares models for Arm Cortex-M microcontrollers, where memory and compute resources are much more limited than on application-class CPUs. The backend rewrites supported quantized operators so they can use CMSIS-NN, an Arm library of optimized neural network kernels for Cortex-M processors.
CMSIS-NN exists to make common ML operations such as convolutions, fully connected layers, activations, and quantization-related operations run efficiently on small embedded CPUs. Use this first .pte to learn the Model Explorer interface while seeing how an ExecuTorch graph can reflect Cortex-M-specific lowering.
Note
The Cortex-M backend is a work-in-progress proof of concept. It’s not intended for production use, and APIs might change without notice. However, the .pte is pre-generated for you in the provided repository. To learn more about the Cortex-M backend, see the Cortex-M Backend Documentation , which also links to a Jupyter Notebook.
To inspect the Cortex-M PTE, follow these steps:
  1. In Model Explorer, open ml-model-artifacts/pte/mv2_cortex_m.pte.
Image Alt Text:Model Explorer Select Models screen showing the TOSA, VGF, and PTE extensions loaded and mv2_cortex_m.pte selected, ready to open with View selected models.Model Explorer with the Arm adapters and Cortex-M PTE selected
  1. Select View selected models.
Image Alt Text:Top-level Cortex-M PTE graph showing Graph Inputs, the collapsed forward layer, and Graph Outputs. Expand forward to inspect the execution graph.Top-level Cortex-M PTE graph
The graph information panel shows the op node count and layer count. The op node count is the number of operator nodes in the graph. The layer count is the number of hierarchical graph components represented in the current view, not necessarily the number of neural network layers in the original model.
  1. Expand the forward layer to view its operators. Select an operator, such as cortex_m::quantize_per_tensor, to see its attributes, inputs, and outputs in the node information panel.
Image Alt Text:Expanded Cortex-M graph with cortex_m::quantize_per_tensor selected. The node information and View on nodes panels expose its attributes, inputs, outputs, and KernelCall metadata.Cortex-M operator metadata in Model Explorer
When you inspect a .pte for the first time, focus on the higher-level graph information first:
  • Operator names show the work the ExecuTorch program will perform.
  • Inputs and outputs show how tensors flow through the graph.
  • Tensor shapes and types help you check whether the model was exported and quantized as expected.
  • Hierarchical layers let you expand or collapse parts of the graph so you can move between an overview and individual operators.
  • Delegate or backend-specific names show where a backend flow has changed the graph. In this Cortex-M example, names such as cortex_m::... indicate operators affected by the Cortex-M backend flow.
You might also see lower-level .pte execution fields in the node attributes. These fields come from the serialized ExecuTorch program:
FieldWhat it means
instruction type: KernelCallThe instruction calls an ExecuTorch operator kernel. A kernel is the code that executes a model operator for a runtime or backend.
instr_args_type: 1The internal FlatBuffer type tag for the instruction arguments. In this case, 1 identifies the arguments as a KernelCall.
op_indexAn index into the .pte operator table. It tells ExecuTorch which operator this instruction calls.
args: [471, 473, 474, ...]Indexes into the .pte values table. These entries identify the tensors or other values used as inputs and outputs by the instruction.
You don’t need to memorize these internal fields. Use the fields as clues when you want to connect a visible graph node to the underlying ExecuTorch program structure.
  1. Select the eye icon in the toolbar to open the View on nodes panel.
  2. Select the data you want to display, such as Op node id and Op node attributes, to show more information in the graph.
You’ve launched Model Explorer with the Arm extensions and confirmed the installation by opening your first .pte artifact. You’ve also learned how to inspect the graph overview, expand into the forward layer, read operator metadata, and interpret common low-level .pte fields such as KernelCall, op_index, and args.
Next, you’ll keep the same browser tab open and compare portable and XNNPACK .pte artifacts to see how backend delegation changes the graph.
