Model Explorer and Arm extensions
Model Explorer is an open-source, web-based graph visualizer and debugger from Google AI Edge. The visualizer provides a hierarchical view of model graphs. You can expand and collapse layers, search for nodes, inspect metadata, highlight inputs and outputs, compare models, and add overlays to graph nodes. The default version, contained in the Model Explorer GitHub repository , supports TFLite, TF, TFJS, MLIR, and PyTorch (Exported Program) formats.
Model Explorer uses adapters and data providers to load formats beyond the built-in model types. The ExecuTorch extension for Model Explorer combines support for .pte, .etrecord, and .etdp files. Standalone .tosa and .vgf files use separate Tensor Operator Set Architecture (TOSA) and VGF adapters. You’ll install all three packages together in the next section.
What you will do
This Learning Path is about model artifacts, not model training or export. You’ll start from small pre-generated files and use each to understand when you’d use Model Explorer, and what insights you can gain.
You’ll use the following artifacts:
ArtifactModel Explorer supportWorkflow layerUse it to inspect
.ptePTE adapter in the ExecuTorch extensionExecuTorch programDelegate regions, backend partitioning, work outside delegates, and the deployed ExecuTorch graph
.tosaSeparate TOSA adapterCompiler or backend intermediate representationLowered operators, tensor shapes, quantized types, graph splits, and missed optimization opportunities
.vgfSeparate VGF adapterGraph artifact for the ML extensions for VulkanInputs, outputs, constants, tensor metadata, graph connectivity, and SPIR-V graph modules
.etrecordETRecord adapter in the ExecuTorch extensionExport-time profiling contextGraph structure, debug handles, operator names, and delegate metadata used to map runtime events back to graph nodes
.etdpETDump data provider in the ExecuTorch extensionRuntime trace overlayTiming data from a specific execution
You’ll focus on Arm adapters and extensions for Model Explorer, but the artifacts repository also includes .tflite and .pt2 files. You can optionally try these files because Model Explorer supports them without an additional adapter.
Note
Model Explorer visualizes the specific artifact you generated or received. Small differences in the target the model has been delegated to can result in a very different model graph. For example, delegating the same model to an Ethos-U55, might produce a very different model graph from delegating to an Ethos-U85.
Understand the model artifact flow
Not every graph in this Learning Path needs to start with PyTorch and ExecuTorch.
PTE is ExecuTorch-specific. A .pte file is the serialized ExecuTorch program loaded by the ExecuTorch runtime. Baseline portable-kernel, XNNPACK, Cortex-M, Ethos-U, and VGF-backend examples are all ExecuTorch deployment artifacts.
The portable-kernel and XNNPACK routes are Cortex-A CPU routes. Cortex-M uses a separate ExecuTorch flow that applies CMSIS-NN-oriented passes for supported quantized operators.
For Ethos-U, the ExecuTorch backend uses the Ethos-U Vela compiler to compile TOSA flatbuffers into an Ethos-U command stream that’s packaged into the final .pte.
TOSA is not inherently ExecuTorch-specific. TOSA is an intermediate representation (IR) that can sit between a model frontend and an Arm backend compiler or converter. ExecuTorch can lower supported graph partitions to TOSA, but another framework can also provide its own TOSA exporter and generate .tosa files.
      PyTorch model
        v
      ExecuTorch export
        +-- Cortex-A portable kernels -> baseline .pte
        +-- Cortex-A XNNPACK delegate -> XNNPACK .pte
        +-- Cortex-M CMSIS-NN passes -> Cortex-M .pte
        +-- Lower to TOSA -----------+
      Alternative frontend           |
      with TOSA export --------------+
                                     v
                                TOSA (.tosa)
                                     +-- Ethos-U Vela
                                     |     -> command stream
                                     |     -> Ethos-U .pte
                                     +-- ML SDK Model Converter
                                           -> VGF payload
                                           -> VGF-backend .pte
                                           -> standalone .vgf
                                              for workflows using the ML extensions for Vulkan
For VGF, the ExecuTorch Arm VGF backend uses the Arm ML SDK Model Converter to produce a VGF backend payload from TOSA. But the Arm ML SDK Model Converter can be used to convert .tosa files generated from a different flow, so VGF is also not specific to ExecuTorch.
When ExecuTorch is used for VGF, a .pte is emitted as well. Use that VGF-backend .pte when you want to run through ExecuTorch. Use the standalone .vgf when you want to inspect or integrate the VGF artifact used with the ML extensions for Vulkan, such as in a neural graphics workflow.
If you’ve used the Arm Neural Graphics Model Gym , then you’ve been using ExecuTorch to export your neural graphics model to VGF. To learn more, see the Fine-tune neural graphics using Model Gym Learning Path, which briefly introduces Model Explorer.
ETRecord and ETDump are additional ExecuTorch-specific artifacts. ETRecord is generated at export time and preserves the graph context needed for profiling attribution. ETDump is generated at runtime and records what happened when a .pte ran. Together, these artifacts let Model Explorer move from static inspection to runtime overlays.
Terminology
The following is a glossary of different terms used in this Learning Path:
TermMeaning in this Learning Path
ModelThe neural network you want to deploy, before or after transformation by export and compiler tools.
FrameworkThe software used to define or train the model, such as PyTorch.
ExportThe step that turns a framework model into a deployable or compiler-friendly representation.
ArtifactA file produced by export, lowering, compilation, or conversion, such as .pte, .tosa, or .vgf.
RuntimeThe software on the target system that loads and executes a deployable artifact. ExecuTorch is the runtime for .pte files.
CompilerA tool that transforms an intermediate representation into a lower-level target representation, such as Vela compiling TOSA for Ethos-U.
LowerTo transform a model or graph from a higher-level representation into a lower-level representation closer to a target backend.
ConvertTo change one artifact format into another, such as TOSA to VGF.
Intermediate representationA representation between the original model and the final target artifact. TOSA is the main intermediate representation in this Learning Path.
DelegateA backend-specific execution path that handles supported parts of a graph. Unsupported parts can remain outside the delegate, and can run on a CPU path only when the deployed runtime includes compatible kernels.
KernelThe code that executes a model operator for a specific runtime or backend, such as a portable ExecuTorch kernel or a CMSIS-NN kernel.
FlatbufferA compact binary serialization format. TOSA flatbuffers store TOSA graphs, and .pte files use a FlatBuffer-based ExecuTorch program format.
SPIR-VStandard Portable Intermediate Representation - Vulkan (SPIR-V) modules inside VGF files describe the data graph used by the ML extensions for Vulkan.
ETRecordAn ExecuTorch export-time debug artifact that preserves graph and delegate metadata for profiling attribution.
ETDumpAn ExecuTorch runtime trace artifact that can record operator, delegate, backend, timing, and cycle-count events from execution. The first Model Explorer overlay used in this Learning Path focuses on timing data.
What models you will use
You’ll use the following pre-provided model artifacts provided purely for educational purposes:
        ml-model-artifacts/
├── pte/
│   ├── mv2_cortex_m.pte
│   ├── gpt2_cortex_a_portable.pte
│   ├── gpt2_cortex_a_xnnpack.pte
│   ├── mv2_fp32_ethos_u85.pte
│   ├── mv2_int8_ethos_u85.pte
│   ├── mv2_lrn_int8_ethos_u85.pte
│   └── small_upscaler_ptq_vgf.pte
├── tosa/
│   ├── mv2_fp32.tosa
│   ├── mv2_int8.tosa
│   ├── mv2_lrn_int8_1.tosa
│   ├── mv2_lrn_int8_2.tosa
│   ├── small_upscaler_ptq.tosa
│   └── small_upscaler_qat.tosa
├── vgf/
│   └── small_upscaler_ptq.vgf
├── etrecord/
│   ├── gpt2_portable.etrecord
│   ├── gpt2_xnnpack.etrecord
│   ├── mobilenetv2_fp32_ethosu.etrecord
│   ├── mobilenetv2_int8_ethosu.etrecord
│   └── mobilenetv2_lrn_int8_ethosu.etrecord
└── etdump/
    ├── gpt2_portable.etdp
    ├── gpt2_xnnpack.etdp
    ├── mobilenetv2_fp32_ethosu.etdp
    ├── mobilenetv2_int8_ethosu.etdp
    └── mobilenetv2_lrn_int8_ethosu.etdp
You’ve now learned how the combined ExecuTorch extension and the separate TOSA and VGF adapters add artifact formats to Model Explorer. You’ve also seen how .pte, .tosa, .vgf, .etrecord, and .etdp files support Cortex-A, Cortex-M, Ethos-U, the ML extensions for Vulkan, and ExecuTorch profiling workflows.
Next, you’ll install Model Explorer and the Arm extensions.
