Accelerate ERNIE-4.5 with Armv9 optimizations
In previous sections, you learned how MoE enables large model deployment on CPUs, and how to observe inference behavior with ERNIE-4.5. You’ll now optimize performance using Armv9 architecture features and benchmark the improvements.
This section shows how to benchmark performance under two scenarios: with and without Armv9 vector instruction optimizations.
You compare a baseline using a regular CPU build against an optimized version that’s an Armv9-specific build with SVE, i8mm, and dotprod instructions enabled.
To establish baseline performance, first compile llama.cpp without Armv9 optimizations.
Disable llama.cpp Armv9 optimizations
This step builds llama.cpp without Armv9 vector features to establish a baseline.
cd $HOME/llama.cpp
mkdir build_v9_off && cd build_v9_off
cmake \
  -DLLAMA_CURL=OFF \
  -DGGML_LLAMAFILE=OFF \
  -DGGML_VULKAN=OFF \
  -DBUILD_SHARED_LIBS=OFF \
  -DCMAKE_SYSTEM_PROCESSOR=arm64 \
  -DCMAKE_OSX_ARCHITECTURES=arm64 \
  -DGGML_NATIVE=OFF \
  -DGGML_AVX=off \
  -DGGML_AVX2=off \
  -DGGML_AVX512=off \
  -DGGML_FMA=off \
  -DGGML_F16C=off \
  -DGGML_CPU_KLEIDIAI=OFF \
make -j$(nproc)
Run the benchmark in the build_v9_off directory:
./bin/llama-bench -m $HOME/models/ernie-4.5/ERNIE-4.5-21B-A3B-Thinking-Q4_0.gguf -pg 128,128 -t 8
The output is similar to:
modelsizeparamsbackendthreadstestt/s
ernie4_5-moe 21B.A3B Q4_011.64 GiB21.83 BCPU8pp51214.96 ± 0.01
ernie4_5-moe 21B.A3B Q4_011.64 GiB21.83 BCPU8tg12812.03 ± 0.02
ernie4_5-moe 21B.A3B Q4_011.64 GiB21.83 BCPU8pp128+tg12813.51 ± 0.03
With the baseline captured, recompile with Armv9 vector extensions enabled.
Enable llama.cpp Armv9 optimizations
Rebuild with vector extensions enabled (i8mm, dotprod, SVE) using the following configuration settings:
cd $HOME/llama.cpp
mkdir build_v9_on && cd build_v9_on
cmake \
  -DLLAMA_CURL=OFF \
  -DGGML_VULKAN=OFF \
  -DCMAKE_SYSTEM_PROCESSOR=armv9-a \
  -DGGML_NATIVE=OFF \
  -DGGML_AVX=off \
  -DGGML_AVX2=off \
  -DGGML_AVX512=off \
  -DGGML_FMA=off \
  -DGGML_F16C=off \
  -DGGML_CPU_ARM_ARCH=armv9-a+i8mm+dotprod+sve \
  -DGGML_CPU_KLEIDIAI=ON \
make -j$(nproc)
Note
This build disables GPU and other backend support to focus on CPU performance and optimization for this Learning Path.
Re-run the benchmark in the build_v9_on directory:
ernie4_5-moe 21B.A3B Q4_011.64 GiB21.83 BCPU8pp51238.51 ± 0.11
ernie4_5-moe 21B.A3B Q4_011.64 GiB21.83 BCPU8tg12815.96 ± 0.08
ernie4_5-moe 21B.A3B Q4_011.64 GiB21.83 BCPU8pp128+tg12821.58 ± 0.11
Compare the results side by side to see the performance gained.
Compare performance: Armv9 optimization results
After running benchmarks with and without Armv9-specific instructions, the results show significant gains.
Testv9 offv9 onGain
pp51214.96 token/s38.51 token/s2.57x
tg12812.03 token/s15.96 token/s1.32x
pp128 + tg12813.51 token/s21.58 token/s1.59x
Vectorized kernels (i8mm, dotprod, SVE) drastically improve inference throughput. The pp512 test shows the most significant acceleration with a 2.57× improvement. Other patterns like tg128 and pp128+tg128 also achieve measurable gains. These results demonstrate the broad benefit of hardware-aware builds and show that Armv9 optimization enables practical real-time inference for 21 B models on edge-class hardware.
What you’ve accomplished
Throughout this Learning Path, you deployed a 21-billion-parameter Chinese MoE model on edge-class Armv9 hardware. You started by understanding how MoE reduces memory usage by activating only a small subset of parameters per token. After setting up llama.cpp on a Radxa O6 board, you compared ERNIE-4.5 Thinking and PT model behaviors while examining expert routing logic with debug instrumentation. Finally, you applied Armv9 hardware optimizations and achieved over 2.5× speed improvements in token throughput.
You can now deploy, profile, and tune Chinese LLMs for efficient inference on modern Arm CPUs.
