Example 2: matrix multiplication
Use a text editor to save the program below in a file named eigen-test3.cpp:
#include <iostream>
#include <Eigen/Dense> // provides dense
#define N 100
using namespace Eigen;
int main()
  MatrixXd A = MatrixXd::Random(512, 512);
  MatrixXd B = MatrixXd::Random(512, 512);
  MatrixXd C = MatrixXd::Zero(512, 512);
  for (int i = 0; i < N; i++) {
    C += A * B;
  std::cout << "C.norm(): " << C.norm() << std::endl;
This example performs N Matrix multiplications and additions. It uses the FMA instructions in most CPUs. It performs this operation on large 512 x 512 matrices and prints the norm() of the final matrix, which should be the same on both ASIMD and SVE versions.
As before, you can first compile and run with vectorization disabled to establish a reference level for performance.
        g++ -O3 -DNDEBUG -DEIGEN_DONT_VECTORIZE eigen-test3.cpp -o eigen-test3 -Ieigen
time ./eigen-test3
__output__C.norm(): 384919
__output__
__output__real    0m2.806s
__output__user    0m2.794s
__output__sys     0m0.012s
Testing on ASIMD
Now, build with ASIMD backend, by removing the -DEIGEN_DONT_VECTORIZE option from the compiler invocation.
        g++ -O3 -DNDEBUG eigen-test3.cpp -o eigen-test3 -Ieigen
time ./eigen-test3
__output__
__output__real    0m1.288s
__output__user    0m1.280s
__output__sys     0m0.008s
The results vary depending on the CPU and system you are using.
The output above is from an SVE2 platform and shows 2.17x improvement in performance. An Ampere Altra CPU shows 3.55x performance improvement and 3.14x on Apple Silicon with an M3 CPU. There are many variables including the size of the caches, and the level of parallelism in the vector units - which equates to how many units are in the CPU and how many SIMD instructions can be executed in parallel.
Testing on SVE
You can also compile and run with SVE enabled:
        g++ -O3 -DNDEBUG -march=armv8-a+sve -msve-vector-bits=128 -DEIGEN_ARM64_USE_SVE eigen-test3.cpp -o eigen-test3 -Ieigen
 time ./eigen-test3
__output__
__output__real    0m1.751s
__output__user    0m1.747s
__output__sys     0m0.004s
You again see that the SVE build is slower than the ASIMD.
The SVE implementation is still experimental and performance is expected to improve in the future.
Example 3: vector 3D rotation
This example creates an initial random normalized vector v1.
Then it creates N random normalized vectors, rotates them π/4 around the z axis, adds them to the initial vector, and takes the dot product of the initial and the resulting vector.
Finally, it prints the sum of all the dot products.
Use a text editor to save the program below in a file named eigen-test4.cpp:
#include <iostream>
#define N 100000000
int main()
  Vector3f v1 = Vector3f::Random().normalized();
  std::cout << "Vector v1: " << std::endl;
  std::cout << v1 << std::endl;
  double sdp = 0.0;
  AngleAxisf aa = AngleAxisf(M_PI_4f, Vector3f::UnitZ());
  Quaternionf q{aa.toRotationMatrix()};
  for (int i=0; i < N; i++) {
    Vector3f v2 = Vector3f::Random().normalized();
    sdp += v1.dot(v1 + q * v2);
  std::cout << "Sum of Dot Products: " << sdp << std::endl;
Use the same process to build and run without vectorization:
        g++ -O3 -DNDEBUG -DEIGEN_DONT_VECTORIZE eigen-test4.cpp -o eigen-test4 -Ieigen
time ./eigen-test4
__output__Vector v1:
__output__ -0.664879
__output__  0.745716
__output__-0.0429305
__output__Sum of Dot Products: 9.99953e+07
__output__
__output__real    0m5.957s
__output__user    0m5.957s
__output__sys     0m0.000s
Testing on ASIMD
As before, remove the -DEIGEN_DONT_VECTORIZE from the compile command:
        g++ -O3 -DNDEBUG eigen-test4.cpp -o eigen-test4 -I../eigen
time ./eigen-test4
__output__  0.745716
__output__
__output__real    0m5.636s
__output__user    0m5.636s
This is interesting; enabling vectorization doesn’t improve performance, which can be due to multiple reasons.
Optimize SIMD code with vectorization-friendly data layout explains that performance on operations involving data like 3D coordinates might benefit from changing the way data is structured.
One thing to mention is that with the -O3 flag, autovectorization is enabled by default in recent GCC and Clang compilers, so even if you disable explicit vectorization in Eigen, the compiler still tries to attempt to vectorize the code.
In the time period that Eigen was developed, autovectorization was completely out of the question and was almost unreachable in all but the most trivial cases. However, the recent compilers are more advanced and prove to be even better in some cases, such as this one, where the type of object is not optimally designed for vectorization.
Testing on SVE
Compile and run the example with SVE:
        g++ -O3 -DNDEBUG -march=armv9-a -msve-vector-bits=128 -DEIGEN_ARM64_USE_SVE eigen-test4.cpp -o eigen-test4 -Ieigen
 time ./eigen-test4
__output__  0.745716
__output__
__output__real    0m5.718s
__output__user    0m5.718s
Interestingly, SVE performs about the same as the other versions.
You are now ready to build one of the high profile applications that use Eigen with SVE enabled. This application is TensorFlow!
