Give feedback
AI-assisted
Close
Which Zenoh roles do I use for the server, control container, and Raspberry Pi?
Use the Zenoh router in the robot container on the Arm server. Use a Zenoh client session in the control container and another on the Raspberry Pi. Both sessions connect to the router.
How do I get the control container ID before configuring its Zenoh client session?
Run docker ps on the Arm server and find ros_zenoh-control-1. Copy its CONTAINER ID and run docker exec -it <container_id> /bin/bash before editing the session configuration.
Do I need to log out and back in after installing Docker on the Raspberry Pi?
Yes. After adding your user to the docker group, log out and log back in so the new group membership takes effect.
What result should I expect when I list topics on the Raspberry Pi, and what does it confirm?
Expect a full list of topics, roughly 80 entries, including /camera/image_raw, /cmd_vel, /map, and /scan. This confirms that you have ROS 2 graph discovery through the Zenoh client, but it doesn’t by itself prove that message data is arriving.
How do I isolate multiple robots that share a Zenoh router?
Use ROS namespaces when you want one station to supervise several robots while keeping their topics distinguishable. Use separate ROS_DOMAIN_ID values when independent groups must not see one another. Use a Zenoh namespace when you want isolation without changing ROS-side names.
