Why isolation is required
If two robots publish and subscribe with the same names, their ROS 2 graphs overlap. For example, a velocity command published on /cmd_vel could be received by both robots. There are three ways to separate them, at different layers:
OptionIsolation layerApplies to
ROS namespaces (/robot_1/...)ROS graphFleet management: one station supervising several robots, all visible at once
Separate ROS_DOMAIN_IDComplete separationIndependent groups sharing infrastructure without seeing each other
Zenoh namespace (session config)Zenoh key expressionsIsolation without changing any ROS-side naming
rmw_zenoh encodes the domain ID into its key expressions. Unlike DDS, rmw_zenoh accepts any value up to MAX_UINT. Zenoh namespaces are prefixed to key expressions transparently and stripped on receipt, so they never appear in the ROS graph. To account for the prefix, update router-side rules that match key expressions.
ros2 topic list shows the graph visible to your session, filtered by domain, namespace, and access control. It’s not a global view of the network.
For more information, see the rmw_zenoh design documentation .
(Optional) Observe and resolve a collision with a second device
With a second edge device, such as another Raspberry Pi, you can see the problem. Start the same edge container on it, pointed at the same router.
On both devices, run a talker using bash shells in their running containers:
ros2 run demo_nodes_cpp talker
In the bash shell in the robot container, run:
ros2 node list
ros2 topic info /chatter
You should see two nodes sharing the name /talker, and /chatter reports two publishers. The output is similar to:
        Type: std_msgs/msg/String
Publisher count: 2
Subscription count: 0
Duplicate node names aren’t valid in ROS 2. The graph is now ambiguous, and a subscriber can’t tell the two apart.
Now, isolate them. On the second edge device only, set a different ROS domain before starting the talker:
export ROS_DOMAIN_ID=42
The robot container, still on the default ROS domain, sees a single /talker and one publisher. The output is similar to:
Publisher count: 1
The second device’s traffic is invisible to it because rmw_zenoh encodes the ROS domain ID into every key expression.
This is the same mechanism that keeps several groups from interfering when they share one Zenoh router.
What you’ve accomplished
You’ve learned why isolating robots that share the same router is necessary and what methods you can use for isolation. You’ve also optionally resolved a collision with a second device.
If you resolved a collision, you observed that the ROS 2 applications remained unchanged, while rmw_zenoh handled communication across the distributed system.
You can apply this isolation approach when designing distributed ROS 2 deployments in which multiple robots share Zenoh infrastructure.
Next, complete Tune Zenoh for ROS 2 traffic over wireless networks .
