Deploy containerized workloads to Arm-based Linux targets with Topo
Install Topo on your host machine
Use Topo to assess target compatibility
Deploy a compatible containerized workload with Topo
(Optional) Use the Topo VS Code extension
Run
topo health on the host to confirm Topo, SSH, and the container engine are available. To include the target in the check, provide --target or set the TOPO_TARGET environment variable.Pass
--target to the Topo command or set TOPO_TARGET in your environment. The health check output prompts you when a target is not specified.Topo detects hardware capabilities on the target, including Arm CPU features such as Neon and SVE, and uses them to identify compatible projects when you run
topo projects --target.Clone the LLM chat project with
topo clone. The default configuration uses the unsloth/SmolLM2-135M-Instruct-GGUF model and can be deployed immediately.Topo builds container images on the host, transfers them to the target over SSH, and starts the services on the target. It can also build and deploy directly on the target if you choose that workflow.
