Before you begin
Topo is an open-source command-line tool developed by Arm that you can use to deploy projects to an Arm-based Linux target over SSH. Topo builds container images on the host, transfers them to the target, and starts the services on the target. Topo can also build and deploy directly on the target.
Before getting started with this Learning Path, complete the Learning Path Deploy containerized workloads to Arm-based Linux targets with Topo .
After completing the Learning Path, you’ll have Topo installed on your host machine and an Arm-based Linux target available over SSH.
You’ll use the same target pattern in this Learning Path as the previous one. The target can be a Raspberry Pi, an Arm-based Amazon EC2 instance, or another Arm-based Linux system:
--target user@my-target
If your host machine is also a Linux target, you can use --target localhost.
What a Topo Template is
A Topo Template is a containerized sample project for Arm-based Linux systems. At minimum, it’s a directory containing a compose.yaml, Dockerfiles, and source code. The compose.yaml file contains an x-topo metadata block that describes what the Topo Template does, what hardware features it requires, and what parameters a user can configure.
The Topo Template Format Specification is based on the Compose Specification , extended with x-topo metadata that describes requirements such as CPU features and build arguments.
The Compose Specification is a standard, YAML-based format for describing multi-container applications. Instead of starting containers individually, you define all services, images, connections, and configuration in a single compose.yaml file.
By creating a Topo Template, you enable deployment of your project with Topo or any other tool that supports the Topo Template format specification. By including your Topo Template in the Topo Catalog, you can share your project with the community for others to deploy.
Where you can find Topo Templates
The Topo Template specification is an open specification. Anyone can publish their own Topo Templates. Any tool can read and act on x-topo metadata to discover, validate, and deploy templates.
You can find a curated list of example Topo Templates using the topo templates command used in the previous Learning Path:
topo templates --target user@my-target
Alternatively, you can find Topo Templates in the Topo Catalog .
To propose adding a Topo Template you created to the template list, see Propose your template to Topo .
How you can create a Topo Template
To create a Topo Template, start with a Docker Compose project and add x-topo metadata. The x-topo section extends the Compose file with Topo-specific information, such as:
  • Build arguments
  • Hardware requirements (features such as Scalable Vector Extension (SVE) or Neon, or required RAM)
  • Clone-time project configuration
You now understand what a Topo Template is, and why you might create one.
Next, you’ll clone and deploy an existing Topo Template.
