If you already have a Docker Compose project and want to convert it to a Topo Template, you can do so with an Agent Skill. You can also use a skill to create your own Topo Template from scratch. These skills are optional authoring aids.
The Topo Template Format Specification currently provides the following skills:
topo-template-context: provides Topo and Topo Template reference context for questions about x-topo metadata, schema, docs, and CLI template behavior.topo-template-bootstrap: converts a repository into a Topo Template by adding or improving compose.yaml and x-topo metadata.topo-template-lint: reviews an existing Topo Template for correctness, consistency, and authoring best practices.For the most up-to-date list of the available Topo Template skills, see Topo Skills .
Install the Topo Template skills with npx skills :
npx requires Node.js. If you don’t have Node.js installed on your machine, install it before running the following command.
npx skills add arm/topo-template-format --all --yes
Restart your AI coding agent after installing or updating skills to make sure new skills are loaded for use.
After installing skills, you can prompt your agent to use a skill.
For example, to create a Topo Template from an existing project:
Use the topo-template-bootstrap skill to convert this repository into a Topo Template.
You’ve now learned how you can install and use Agent Skills to help author Topo Templates.
You can now create, modify, and deploy Topo Templates to Arm-based Linux targets. To find more templates to clone and modify, explore the Topo Catalog .
