# Learn about Topo Projects
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/)
- [Learn about Topo Projects](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/overview/)
- [Clone and deploy the Hello World Topo Project](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/hello-world-project/)
- [Modify the Hello World Topo Project](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/modifying-hello-world/)
- [Create a new Topo Project from an empty directory](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/creating-a-new-project/)
- [Use Agent Skills to author Topo Projects](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/agent-skills/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/create-your-own-topo-project/_next-steps/)
## Before you begin
[Topo](https://github.com/arm/topo) is an open-source command-line tool developed by Arm that you can use to deploy projects to an Arm-based Linux target over SSH. Topo builds container images on the host, transfers them to the target, and starts the services on the target. Topo can also build and deploy directly on the target.
Before getting started with this Learning Path, complete the Learning Path [Deploy containerized workloads to Arm-based Linux targets with Topo](https://learn.arm.com/learning-paths/cross-platform/deploy-containerized-workloads-with-topo/).
After completing the Learning Path, you’ll have Topo installed on your host machine and an Arm-based Linux target available over SSH.
You’ll use the same target pattern in this Learning Path as the previous one. The target can be a Raspberry Pi, an Arm-based Amazon EC2 instance, or another Arm-based Linux system:
--target user@my-target
If your host machine is also a Linux target, you can use `--target localhost`.
## What a Topo Project is
A Topo Project is a containerized sample project for Arm-based Linux systems. At minimum, it’s a directory containing a `compose.yaml`, Dockerfiles, and source code. The `compose.yaml` file contains an `x-topo` metadata block that describes what the Topo Project does, what hardware features it requires, and what parameters a user can configure.
The [Topo Project specification](https://github.com/arm/topo/tree/main/docs/project-specification) is based on the [Compose Specification](https://github.com/compose-spec/compose-spec), extended with `x-topo` metadata that describes requirements such as CPU features and build arguments.
The Compose Specification is a standard, YAML-based format for describing multi-container applications. Instead of starting containers individually, you define all services, images, connections, and configuration in a single `compose.yaml` file.
By creating a Topo Project, you enable deployment of your project with Topo or any other tool that supports the Topo Project specification. By including your Topo Project in the Topo Catalog, you can share your project with the community for others to deploy.
## Where you can find Topo Projects
The Topo Project specification is an open specification. Anyone can publish their own Topo Projects. Any tool can read and act on `x-topo` metadata to discover, validate, and deploy projects.
You can find a curated list of example Topo Projects using the `topo projects` command used in the previous Learning Path:
topo projects --target user@my-target
Alternatively, you can find Topo Projects in the [Topo Catalog](https://github.com/arm/topo-project-catalog/blob/main/data/catalog.json).
To propose adding a Topo Project to the catalog, validate it against the [Topo Project specification](https://github.com/arm/topo/tree/main/docs/project-specification), then open a pull request in the [Topo Project Catalog](https://github.com/arm/topo-project-catalog) repository to update [data/github_sources.json](https://github.com/arm/topo-project-catalog/blob/main/data/github_sources.json).
## How you can create a Topo Project
To create a Topo Project, start with a Docker Compose project and add `x-topo` metadata. The `x-topo` section extends the Compose file with Topo-specific information, such as:
- Project parameters that can be wired to Docker build arguments
- Hardware requirements (features such as Scalable Vector Extension (SVE) or Neon)
- Clone-time project configuration
## What you’ve accomplished and what’s next
You now understand what a Topo Project is, and why you might create one.
Next, you’ll clone and deploy an existing Topo Project.
