Skills for authoring Topo Projects
If you already have a Docker Compose project and want to convert it to a Topo Project, you can do so with an Agent Skill. You can also use a skill to create your own Topo Project from scratch. These skills are optional authoring aids.
Topo currently provides the following skills:
  • topo-project-context: provides Topo and Topo Project reference context for questions about x-topo metadata, schema, docs, and CLI project behavior.
  • topo-project-bootstrap: converts a repository into a Topo Project by adding or improving compose.yaml and x-topo metadata.
  • topo-project-lint: reviews an existing Topo Project for correctness, consistency, and authoring best practices.
  • topo-project-optimize-deployment: optimizes feedback loop by measuring and applying the highest-leverage Docker build improvement.
For the most up-to-date list of the available Topo skills, see Topo Skills .
Install the skills
Install the Topo skills with npx skills :
Note
npx requires Node.js. If you don’t have Node.js installed on your machine, install it before running the following command.
npx skills add arm/topo
Restart your AI coding agent after installing or updating skills to make sure new skills are loaded for use.
Use the skills
After installing skills, you can prompt your agent to use a skill.
For example, to create a Topo Project from an existing project:
Use the topo-project-bootstrap skill to convert this repository into a Topo Project.
What you’ve accomplished
You’ve now learned how you can install and use Agent Skills to help author Topo Projects.
You can now create, modify, and deploy Topo Projects to Arm-based Linux targets. To find more projects to clone and modify, explore the Topo Catalog .
