You should see a new directory at the path you provided (for example,
~/topo-welcome) and clone output that includes lines like Copy files and Cloning into .... After cloning, the project’s services can be deployed to the Arm-based Linux target as shown in the steps.Add it under the
x-topo parameters section in compose.yaml, alongside the existing GREETING_NAME parameter. Define the parameter name and metadata there so Topo can surface it during cloning.Clone and deploy the updated project, then check the running service’s behavior for your change. For example, the Hello World greeting should include the emoji you configured, or the sample webpage should reflect your chosen text and color.
Include a
compose.yaml with standard Compose services, an x-topo metadata block, and project parameters wired to Docker build arguments when needed. The container image should be built for Arm Linux targets.Use Agent Skills as optional aids when you want help creating or converting a project into a Topo Project. Topo provides
topo-project-context for reference about x-topo and CLI behavior and topo-project-bootstrap to help convert a repository into a Topo Project.
