The following C++ program takes user input as the loop size so that the loop size max_loop_size is only known at runtime. This initializes an array of size max_loop_size with the value for each element corresponding to the index position.
The function foo() loops through each element to print out the sum of all elements. Without any boundary information provided to the compiler, it must generate conservative code that works for any loop size.
Use a text editor to copy the code below into a file named no-context.cpp.
#include <iostream>
#include <chrono>
void foo(const int* x, int max_loop_size)
int sum = 0;
for (int k = 0; k < max_loop_size; k++) {
sum += x[k];
std::cout << "Sum: " << sum << std::endl;
int main() {
int max_loop_size;
std::cout << "Enter a value for max_loop_size (must be a multiple of 4): ";
std::cin >> max_loop_size;
int x[max_loop_size];
// Initialize test data
for(int i = 0; i < max_loop_size; ++i) x[i] = i;
// Start timing
auto start = std::chrono::high_resolution_clock::now();
foo(x, max_loop_size);
// Stop timing
auto end = std::chrono::high_resolution_clock::now();
// Calculate and display the elapsed time
auto duration = std::chrono::duration_cast<std::chrono::nanoseconds>(end - start).count();
std::cout << "Time taken by foo: " << duration << " nanoseconds" << std::endl;
return 0;
Compile the program using the following command:
g++ -O3 -march=armv8-a+simd no-context.cpp -o no-context
Run the example with 40000 as the input:
./no-context
You see the output below, your runtime will vary depending on the computer you are using.
Enter a value for max_loop_size (must be a multiple of 4): 40000
Sum: 799980000
Time taken by foo: 138100 nanoseconds
Continue to the next section to see how to use developer knowledge of loops to improve performance.
