# Bare-metal example
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/cca_rme/)
- [Arm Confidential Compute Architecture](https://learn.arm.com/learning-paths/cross-platform/cca_rme/cca/)
- [Bare-metal example](https://learn.arm.com/learning-paths/cross-platform/cca_rme/bare-metal/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/cca_rme/_next-steps/)
Consider a bare-metal example that illustrates the Realm Management Extension (RME) architectural feature of an Arm processor necessary to implement a CCA system.
The full example is provided with Arm Development Studio, 2023.0 or later. It executes on the Arm Architecture Envelope Model (AEM) Fixed Virtual Platform (FVP), supplied with Development Studio.
The example also illustrates features of the Arm Debugger to enable you to debug such a system.
## Import the example
Open the Arm Development Studio IDE. Navigate to File > Import… > Arm Development Studio > Examples & Programming Libraries > Examples > Armv9 Bare-Metal, and select the RME example. Using the text filter at the top of the pane can help locate the example. Click Finish to import.
Alternatively, extract the example on the command line from the `<install_dir>(\examples\Bare-metal_examples_Armv9.zip` archive. For interactive debug (see later) using the IDE is recommended.
Though the project is provided pre-compiled, you can also rebuild with the Build icon, or the `make` command from the command line.
See the supplied readme.html for more information.
## Load the example
There is a supplied `gpc_el10_rl_FVP.launch` debug connection which has all the necessary settings configured.
Double-click on the .launch file to open.
The Arm Architecture Envelope Model (AEM) is a generic Arm implementation, which can be configured appropriately to enable Arm architectural features.
The model is launched with appropriate settings to implement full RME support, including:
-C cluster0.has_arm_v9-0=1 -C cluster0.rme_support_level=2 -C cluster0.has_16k_granule=1
Click Debug to launch the FVP and load the image.
Execution can be controlled by the Debug Control view icon bar, e.g., Step Instruction, the command line (`stepi`), or short-cut keys (F5).
## Understand the example
### EL3
The example sets up a Granule Protection Table (GPT) that defines the access permissions of various 16KB granules of memory. These granules are the smallest memory size that can be individually managed.
These settings are made at EL3 running in Root world, and so will be invisible to any application executing within a Realm.
The location of this table is set in the [Granule Protection Table Base Register (GPTBR_EL3)](https://developer.arm.com/documentation/ddi0601/2023-06/AArch64-Registers/GPTBR-EL3--Granule-Protection-Table-Base-Register).
The high level configuration is defined in the [Granule Protection Check Control Register (GPCCR_EL3)](https://developer.arm.com/documentation/ddi0601/2023-06/AArch64-Registers/GPCCR-EL3--Granule-Protection-Check-Control-Register--EL3-).
Notable fields in this register are:
- Granule Protection Check Enable (GPC) bit
- Level 0 GPT Size (L0GPTSZ) field, defining the size of the level 0 entries in this table, which is 1GB in this example. This will further be separated in the L1 table.
- Physical Granule Size (PGS) field, which in this example defines the granule size as 16KB (note that this matches the AEM configuration).
- Protected Physical Address Size (PPS) field, which defines the size of the Realms in your system (4GB in this example).
The L0 table is at 0x80018000 and defines a flat memory translation (at EL3), but with access permissions defined in an L1 table.
The L1 table defines permissions for each 16KB granule.
Use the Arm Debugger MMU/MPU pane to observe these attributes:
![Screenshot of Arm Debugger MMU/MPU pane showing L1 Granule Protection Table entries for memory region 0xA0000000, displaying Realm access permissions for 16KB granules](/learning-paths/cross-platform/cca_rme/_images/l1gpt_0xA.png)
![Screenshot of Arm Debugger MMU/MPU pane showing L1 Granule Protection Table entries for memory region 0x80000000, displaying the protection attributes for this address range](/learning-paths/cross-platform/cca_rme/_images/l1gpt_0x8.png)
### EL2
The EL2 translation table provides an Intermediate Physical Address (IPA), which is the Physical Address (from the Realm point of view) that addresses will be translated to. This would be the role of a Hypervisor in a realistic implementation.
This table is located by the [Virtualization Translation Table Base Register (VTTBR-EL2)](https://developer.arm.com/documentation/ddi0601/latest/AArch64-Registers/VTTBR-EL2--Virtualization-Translation-Table-Base-Register).
The example maps 0x5xxxxxxx to the Physical Address 0xBxxxxxxx.
![Screenshot of Arm Debugger MMU/MPU pane showing EL2 translation table mapping virtual address 0x5xxxxxxx to physical address 0xBxxxxxxx through the Intermediate Physical Address](/learning-paths/cross-platform/cca_rme/_images/l2gpt.png)
### EL1 (and EL0)
The code moves to EL1 (Realms are only defined for EL1 and EL0), and translation tables mapping virtual addresses to the EL2 memory map are set up.
The debugger uses [address space prefixes](https://developer.arm.com/documentation/101471/latest/Arm-Debugger-commands/Conformance-and-usage-rules-for-Arm-Debugger-commands/Address-space-prefixes) to help understand how these addresses are used.
For the addresses used in the example:
mmu translate EL1RL:0xD0000020
outputs:
__output__
Realm EL1&0 Stage 1 (AArch64):
__output__
  EL1RL:0x00000000D0000020 -> RLP:0x0000000050000020
__output__
Realm EL1&0 Stage 2 (AArch64):
__output__
  RLP:0x0000000050000020 -> NP:0x00000000B0000020
These addresses can be read from the memory pane or the command line:
x/g EL1RL:0xD0000020
x/g NP:0xB0000020
outputs:
__output__
EL1RL:0x00000000D0000020:  0x0000000011111111
__output__
NP:0x00000000B0000020:  0x0000000011111111
Similarly:
mmu translate EL1RL:0xffffffff00000100
outputs:
__output__
__output__
  EL1RL:0xFFFFFFFF00000100 -> RLP:0x0000000060000100
__output__
__output__
  RLP:0x0000000060000100 -> RLP:0x00000000A0000100
## Demonstrate the protection that RME provides
The reference example successfully completes. We can make changes to the translation tables to see the effect of the protection that RME provides.
Disconnect the debugger, and reconnect.
Before execution, change the translation table entry defining Realms access for the 16KB region at 0xA0000000.
For example, to set for Secure access only, set that least-significant half-byte to 0x8:
memory set 0x80024000 64 0x8
Set a breakpoint on the STR instruction that writes to 0xFFFFFFFF00000100, which translates to 0xA0000100:
MOV64 X1, 0xFFFFFFFF00000100 // mapped to 0xA0000100 RL via IPA 0x60000100
MOV32 X0, 0x22222222
*   STR X0, [X1]
And run (F8) to there. Observe that the physical address (0xA0000100) requires secure access permissions:
![Screenshot of Arm Debugger MMU/MPU pane showing L1 Granule Protection Table after modification, where the 0xA0000000 region now requires secure access permissions indicated by the 0x8 value](/learning-paths/cross-platform/cca_rme/_images/l1gpt_change.png)
However, the Realm (`0xFFFFFFFF00000100`) MMU is unchanged.
![Screenshot of Arm Debugger MMU/MPU pane showing the Realm EL1 translation table for address 0xFFFFFFFF00000100, which remains unchanged despite the physical address protection change](/learning-paths/cross-platform/cca_rme/_images/el1.png)
Execute (F5) the STR instruction, and a memory exception correctly occurs, and the code branches to the vector table (at 0x200).
__output__
Execution stopped in EL1h mode at EL1RL:0x0000000000000200
> **Note**
> The example has not configured the Realm vector table, and so there will also be a memory access error at the vector table. This can be ignored for the purposes of understanding RME behavior.
