Build a Reachy Mini MuJoCo simulation on Raspberry Pi
Learn about Reachy and the Reachy Gladiator application
Start the Reachy simulation on MuJoCo
Set up the Raspberry Pi and run the edge AI app
Use the Reachy Gladiator application
Understand the Reachy Gladiator application code
(Optional) Extend the project
Understand the code structure
The project separates perception, app logic, robot motion, and dashboard rendering.
The key files running on the Pi are:
reachy_gladiator_lp/
├── main.py
├── camera.py
├── gesture.py
├── moves.py
├── assets/
│ └── gesture_recognizer.task
└── static/ # dashboard HTML, CSS, JavaScript, and media
Follow the app lifecycle - main.py
reachy_gladiator_lp/main.py is the center of the application. It defines the ReachyGladiatorLp class, which inherits from ReachyMiniApp.
Two settings are important for the distributed simulation route:
custom_app_url: str | None = "http://0.0.0.0:8042"
request_media_backend: str | None = "no_media"
custom_app_url tells the Reachy app framework where the dashboard is served.
request_media_backend = "no_media" tells the SDK not to request camera media
from the daemon, because the Pi uses its own USB webcam. For a physical Reachy
route, setting REACHY_GLADIATOR_MEDIA_BACKEND=reachy lets the SDK request the
daemon media backend.
The useful part to inspect is run(), because that is where the app receives a
connected ReachyMini object and starts the edge AI loop:
def run(self, reachy_mini: ReachyMini, stop_event: threading.Event) -> None:
rng = random.Random()
move_queue: list[str] = []
last_move: str | None = None
detector: ThumbGestureDetector | None = None
latest_frame: np.ndarray | None = None
self._status = {
"state": "starting",
"round": 0,
"active_move": None,
"gesture": None,
"confidence": 0.0,
"camera_ready": False,
This state drives both sides of the app: robot behavior and dashboard display.
The run() method keeps track of the following:
move_queuestores the shuffled bag of moves.last_moveprevents immediate repeats at a shuffle boundary.detectorstores the MediaPipe gesture detector.latest_framestores the newest webcam frame from the capture thread.statusstores the data returned by the dashboard/statusendpoint.
The _update_status() helper updates dashboard state safely:
def _update_status(self, **values: Any) -> None:
with self._state_lock:
self._status.update(values)
The nested capture_frames() helper runs in the background. It reads frames from the selected camera source, saves the newest frame for gesture detection, and marks the dashboard camera as ready.
The actual loop is intentionally small:
def capture_frames(frame_source: FrameSource) -> None:
while not stop_event.is_set() and not capture_stop.is_set():
frame = frame_source.get_frame()
if frame is None:
time.sleep(LOOP_SLEEP_S)
continue
self._update_frame(frame)
self._update_status(camera_ready=True)
main.py also registers FastAPI endpoints on settings_app:
/statusreturns the latest round, state, move, gesture, confidence, and camera status./videostreams resized JPEG frames as an MJPEG feed for the browser dashboard.
These routes are registered inside the app class:
@self.settings_app.get("/status")
def get_status() -> dict[str, Any]:
return dict(self._status)
@self.settings_app.get("/video")
def video() -> StreamingResponse:
return StreamingResponse(
self._video_stream(self._read_frame),
media_type="multipart/x-mixed-replace; boundary=frame",
The main loop has four phases:
- Build the next move sequence with
_build_sequence(). - Perform the selected move
MOVE_REPETITIONStimes. - Return to neutral and call
_await_verdict(). - Run
victory(),defeat(), or continue neutrally.
The verdict code requires two consecutive confident classifications before it accepts a gesture. This debounce step helps avoid reacting to a single noisy frame.
This is the core move-and-verdict flow:
sequence = self._build_sequence(rng, move_queue, last_move)
for name in sequence:
move_fn = gmoves.MOVE_CATALOGUE[name]
for repeat_idx in range(1, MOVE_REPETITIONS + 1):
self._update_status(active_move=name, current_repeat=repeat_idx)
move_fn(reachy_mini)
gmoves.neutral(reachy_mini)
verdict, detector = self._await_verdict(
reachy_mini,
self._read_frame,
detector,
stop_event,
self._update_status,
The app is still a normal Reachy Mini app. It receives a connected
ReachyMini object in run(). That object is the SDK boundary, so the rest of
the app doesn’t need to know whether commands go to MuJoCo simulation or to a
physical robot.
Capture camera frames - camera.py
reachy_gladiator_lp/camera.py selects the frame source. A frame source is
anything that can return the next camera image as a NumPy array.
For the default simulation-plus-Pi route, frames come from a USB webcam plugged into the Raspberry Pi. The app uses OpenCV to open that webcam and read frames:
self._capture = cv2.VideoCapture(camera_index)
camera_index is the local video-device number on the Pi. Index 0 usually
means the first camera OpenCV can open, and index 1 means the next one. If
REACHY_GLADIATOR_CAMERA_INDEX=1 worked in the camera check, use the same
value when running the app.
For the physical Reachy route, frames come from the Reachy daemon media
pipeline instead. In that case, camera_index isn’t used.
The REACHY_GLADIATOR_CAMERA environment variable chooses the route:
opencvuses a local USB webcam through OpenCV.reachyuses camera frames from the Reachy daemon.
The source selection code is therefore small:
requested = os.getenv("REACHY_GLADIATOR_CAMERA", "opencv").strip().lower()
if requested == "opencv":
return OpenCVCameraFrameSource(_camera_index())
if requested == "reachy":
return ReachyMediaFrameSource(reachy_mini)
After a frame is captured, the latest frame is copied into shared state. Both the detector and dashboard stream read from that newest frame. This lets the same app use either a Pi USB webcam or the physical Reachy camera without changing the gesture-recognition code.
Recognize thumbs with MediaPipe - gesture.py
reachy_gladiator_lp/gesture.py runs the MediaPipe Gesture Recognizer. This is
the edge AI part of the app: the Raspberry Pi classifies camera frames locally
and sends only robot commands over the network.
The recognizer loads this model bundle:
reachy_gladiator_lp/assets/gesture_recognizer.task
The .task file is a MediaPipe Tasks model bundle. It includes the trained
gesture-recognition model and the metadata MediaPipe needs to run it through
the Tasks API.
Under the hood, MediaPipe Tasks commonly runs the model through TensorFlow Lite for efficient on-device inference. On CPU builds, TensorFlow Lite can use the XNNPACK delegate to speed up neural-network operations on Arm CPUs.
The detector runs in a worker process instead of the main app thread. This keeps MediaPipe inference separate from the robot-control loop, dashboard responses, and camera capture. The robot-control loop and dashboard server therefore remain responsive when MediaPipe is classifying a frame.
The app uses the CPU delegate:
base_options = python.BaseOptions(
model_asset_path=model_path,
delegate=python.BaseOptions.Delegate.CPU,
The recognizer is configured for one hand in image mode:
options = vision.GestureRecognizerOptions(
base_options=base_options,
running_mode=vision.RunningMode.IMAGE,
num_hands=1,
min_hand_detection_confidence=0.5,
min_hand_presence_confidence=0.5,
min_tracking_confidence=0.5,
Each OpenCV frame is converted from BGR to RGB before MediaPipe sees it. BGR and RGB contain the same red, green, and blue color channels, but in a different order. OpenCV returns webcam frames as blue-green-red, but MediaPipe expects red-green-blue:
rgb_frame = bgr_frame[:, :, ::-1].copy()
mp_image = mediapipe.Image(image_format=mediapipe.ImageFormat.SRGB, data=rgb_frame)
result = recognizer.recognize(mp_image)
The app then maps MediaPipe labels to its own labels:
if raw_label == "Thumb_Up":
label = "thumbs_up"
elif raw_label == "Thumb_Down":
label = "thumbs_down"
else:
label = None
The returned GestureResult also includes the thumb tip pixel position. The worker queues have maxsize=1, which keeps detection biased toward the newest camera frame.
The app also warms the detector in the background while Reachy is preparing. This means the first verdict window doesn’t have to pay all of the detector startup cost:
def warmup_detector() -> None:
warmed_detector = ThumbGestureDetector()
frame = self._read_frame()
if frame is not None:
warmed_detector.detect(frame)
break
When the verdict window starts, the app reuses the warmed detector if it’s ready:
if detector is None:
detector_warmup_done.wait(timeout=GESTURE_WARMUP_WAIT_S)
with detector_warmup_lock:
detector = detector_warmup["detector"]
detector_warmup["detector"] = None
The debounce logic accepts a verdict after only two matching confident frames:
if (
result.label in ("thumbs_up", "thumbs_down")
and result.confidence >= VERDICT_MIN_CONFIDENCE
if result.label == last_label:
consecutive += 1
else:
last_label = result.label
consecutive = 1
if consecutive >= 2:
return result.label, detector
Send robot motion commands - moves.py
reachy_gladiator_lp/moves.py contains small robot motion primitives:
Salute, Sword Swing, Shield Up, Battle Cry, victory, defeat, and
neutral. Each move accepts a ReachyMini instance and sends one or more
goto_target() commands.
For example, the salute() move combines a head target with antenna targets:
reachy_mini.goto_target(
head=create_head_pose(pitch=-16, yaw=0, roll=0, degrees=True),
antennas=np.deg2rad([58, 58]),
duration=0.42,
method="minjerk",
create_head_pose(...) builds the head target in degrees. The antenna values
are converted to radians with np.deg2rad(...).
Some moves try to use body yaw:
reachy_mini.goto_target(body_yaw=yaw_rad, duration=duration, method=method)
The helper _safe_body_yaw() catches SDK or hardware cases where body yaw is unavailable and falls back to a smaller head motion.
The move catalogue is as follows:
MOVE_CATALOGUE: dict[str, MoveFn] = {
"Salute": salute,
"Sword Swing": sword_swing,
"Shield Up": shield_up,
"Battle Cry": battle_cry,
Adding a move means writing a new function and registering it in
MOVE_CATALOGUE. That makes the app loop eligible to select and run the move.
To display it cleanly in the dashboard, also add a matching entry to
MOVE_DESCRIPTIONS.
The shuffled bag logic lives in main.py, not in the move functions:
names = list(gmoves.MOVE_CATALOGUE.keys())
if not move_queue:
move_queue.extend(rng.sample(names, len(names)))
if last_move is not None and len(move_queue) > 1 and move_queue[0] == last_move:
move_queue.append(move_queue.pop(0))
return [move_queue.pop(0)]
The victory and defeat reactions are also move functions. The state machine decides when to call them:
if verdict == "thumbs_up":
gmoves.victory(reachy_mini)
elif verdict == "thumbs_down":
gmoves.defeat(reachy_mini)
main.py decides what should happen, and moves.py describes how Reachy should move.
Render the dashboard
Because custom_app_url is set, the Reachy app base class starts a FastAPI
server for this app. That server mounts reachy_gladiator_lp/static/ at
/static and serves static/index.html at /. The files in static/ are
therefore the dashboard you view in the browser:
index.htmldefines the dashboard layout.main.jspolls/statusand updates the DOM.style.csscontrols the arena theme, verdict colors, and responsive layout.reachy_gladiator.pngis the gladiator image shown in the dashboard.
The JavaScript code doesn’t control the robot. It only renders state produced by the Python app.
The dashboard camera feed is an MJPEG stream from /video. Python resizes each frame and encodes it as JPEG:
preview_frame = self._resize_preview_frame(frame)
ok, encoded = cv2.imencode(
".jpg",
preview_frame,
[cv2.IMWRITE_JPEG_QUALITY, DASHBOARD_PREVIEW_JPEG_QUALITY],
static/index.html displays that stream in an image element, while
static/main.js polls /status for the round state, gesture confidence, and
verdict highlighting. This split keeps video transport simple.
The command-line entry point wires the script environment into the Reachy SDK connection:
if __name__ == "__main__":
daemon_host = os.getenv("REACHY_GLADIATOR_DAEMON_HOST", "localhost")
daemon_port = int(os.getenv("REACHY_GLADIATOR_DAEMON_PORT", "8000"))
daemon_timeout = float(os.getenv("REACHY_GLADIATOR_DAEMON_TIMEOUT", "8.0"))
os.environ.setdefault("REACHY_GLADIATOR_CAMERA", "opencv")
os.environ.setdefault("REACHY_GLADIATOR_MEDIA_BACKEND", "no_media")
app = ReachyGladiatorLp()
app.wrapped_run(host=daemon_host, port=daemon_port, timeout=daemon_timeout)
Take some time to read through the files and understand the different parts before moving on to extend the project.
What you’ve learned
You’ve now inspected how the app captures camera frames and runs MediaPipe gesture recognition on the Pi. You’ve also learned how the app debounces thumbs-up and thumbs-down verdicts, sends Reachy SDK motion commands, and renders a browser dashboard.
Next, you can experiment with adapting this project or building your own app.
