# Set up the Raspberry Pi and run the edge AI app
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/)
- [Learn about Reachy and the Reachy Gladiator application](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/reachy-app/)
- [Start the Reachy simulation on MuJoCo](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/start-simulation/)
- [Set up the Raspberry Pi and run the edge AI app](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/run-pi-app/)
- [Use the Reachy Gladiator application](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/use-the-app/)
- [Understand the Reachy Gladiator application code](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/understand-code/)
- [(Optional) Extend the project](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/extend/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/build-a-reachy-robot-app-on-pi/_next-steps/)
## Prepare the Raspberry Pi
Install Raspberry Pi OS Trixie (Debian 13-based) on your Raspberry Pi. Ensure the Pi is accessible over SSH.
Connect to your Raspberry Pi over SSH. If you use VS Code, you can use the [Remote - SSH](https://code.visualstudio.com/docs/remote/ssh) extension. From a terminal:
```bash
ssh <user>@<pi-ip-address>
On your Pi, create a workspace and move into it:
```bash
mkdir -p ~/reachy_projects
cd ~/reachy_projects
Install and enable Git LFS before cloning the app. The MediaPipe gesture model is stored as a Git LFS asset, so a normal clone without LFS can leave a tiny pointer file instead of the real model:
```bash
sudo apt update
sudo apt install git-lfs
git lfs install
Clone the [reachy_gladiator_lp](https://github.com/matt-cossins/reachy_gladiator_lp) project into this directory:
```bash
git clone https://github.com/matt-cossins/reachy_gladiator_lp.git
cd reachy_gladiator_lp
git lfs pull
Check that the gesture model was downloaded:
```bash
ls -lh reachy_gladiator_lp/assets/gesture_recognizer.task
The file should be about 8 MB. If it’s only 132 bytes, run `git lfs pull` again before continuing.
## Install the Pi runtime
Run the Pi setup script. The script can take several minutes to finish running because it installs `pyenv`, builds Python 3.12, and installs all Python dependencies:
```bash
./scripts/setup_pi.sh
The script installs the system packages, Python version, Python packages, and app entry point that you’ll use in this Learning Path.
Raspberry Pi OS Trixie can use Python 3.13 as the default `python3`, but the tested Pi environment for this app uses Python 3.12. The setup script installs Python 3.12.3 with `pyenv` so you don’t need to modify the system Python.
The script also handles the Pi-specific package versions:
- `mediapipe==0.10.18`, because newer MediaPipe wheels aren’t available for the tested Pi environment.
- `numpy==2.4.4`, which is required by the Reachy Mini SDK and has been tested with the gesture worker.
- `reachy-mini==1.7.3`, installed without dependency resolution so pip doesn’t reject the MediaPipe and NumPy combination.
- `git-lfs`, so the MediaPipe gesture model is downloaded as the real binary asset rather than an LFS pointer file.
- `v4l-utils`, so you can inspect connected camera devices with `v4l2-ctl`.
After setup finishes, activate the virtual environment:
```bash
source .venv/bin/activate
The setup script runs an import smoke test. It also runs `pip check`. A MediaPipe NumPy metadata warning is expected for this Pi setup.
## Validate the MediaPipe gesture worker
Test the MediaPipe gesture worker by writing a small test script and running it. The following `cat` command creates the file at `/tmp/test_gesture_worker.py` using a heredoc — the text between `<<'PY'` and the closing `PY` becomes the file contents:
```bash
cat > /tmp/test_gesture_worker.py <<'PY'
import numpy as np
from reachy_gladiator_lp.gesture import ThumbGestureDetector
def main():
    print("creating detector")
    detector = ThumbGestureDetector()
    frame = np.zeros((480, 640, 3), dtype=np.uint8)
    result = detector.detect(frame)
    print(result)
    detector.close()
    print("gesture detector OK")
if __name__ == "__main__":
    main()
PY
python /tmp/test_gesture_worker.py
The output should show that the detector starts and returns a neutral result for the blank test frame:
__output__ creating detector
__output__ GestureResult(label=None, x_px=320, y_px=240, confidence=0.0)
__output__ gesture detector OK
MediaPipe might also print TensorFlow Lite or CPU delegate warnings before the result. The important line is `gesture detector OK`.
## Check the USB webcam
Plug the USB webcam into the Raspberry Pi and list video devices:
```bash
ls /dev/video*
Run the included camera check:
```bash
./scripts/check_pi_camera.sh
The output is similar to:
__output__ Video devices:
__output__ /dev/video0
__output__ Camera index 0 OK: 1280x720
If camera index `0` does not work, try index `1`:
```bash
REACHY_GLADIATOR_CAMERA_INDEX=1 ./scripts/check_pi_camera.sh
If a different camera index works, use the same value when you run the app. For example, if camera index `1` works:
```bash
REACHY_GLADIATOR_CAMERA_INDEX=1 \
REACHY_GLADIATOR_DAEMON_PORT=18000 \
./scripts/run_pi_app.sh <simulation-host-ip>
## Run the distributed app
Keep the simulation terminal running on your simulation host.
On the Raspberry Pi, run the app with the simulation host IP address and the simulation port `18000`:
```bash
REACHY_GLADIATOR_DAEMON_PORT=18000 ./scripts/run_pi_app.sh <simulation-host-ip>
If you started the simulation on a different port, pass that same value in `REACHY_GLADIATOR_DAEMON_PORT`.
### Understand what the script is doing
The script sets the app configuration:
```bash
REACHY_GLADIATOR_DAEMON_HOST=<simulation-host-ip>
REACHY_GLADIATOR_DASHBOARD_HOST=0.0.0.0
REACHY_GLADIATOR_DASHBOARD_PORT=8042
REACHY_GLADIATOR_MEDIA_BACKEND=no_media
REACHY_GLADIATOR_CAMERA=opencv
REACHY_GLADIATOR_CAMERA_INDEX=0
The app then runs:
```bash
python -m reachy_gladiator_lp.main
`REACHY_GLADIATOR_MEDIA_BACKEND=no_media` tells the Reachy SDK not to request camera media from the daemon. This is the right default for the Learning Path because the Pi owns the USB webcam. `REACHY_GLADIATOR_CAMERA=opencv` tells the gesture recognizer to read frames from that local webcam.
## What you’ve accomplished and what’s next
You’ve now installed the Pi runtime with the project setup script, validated the MediaPipe gesture worker, checked the USB webcam, and started the edge AI app. The edge AI app can run Reachy Gladiator, perform inference on incoming frames, and send Reachy commands to the simulation host.
Next, you’ll try out Reachy Gladiator using the application dashboard.
