Before you begin, ensure you have the following installed on your machine:
If you’re on Linux, you need the Python virtual environment package.
For Debian or Ubuntu, run:
sudo apt install -y python3-venv
You can verify Docker is running by executing:
docker info
The output shows your Docker configuration. If Docker isn’t running, start the Docker daemon before proceeding.
First, clone the Arm MCP server repository which contains the test framework:
git clone https://github.com/arm/mcp.git
cd mcp
The integration tests require a locally built Docker image of the MCP server. Build it from the repository root:
docker buildx build -f mcp-local/Dockerfile -t arm-mcp .
This command creates a Docker image tagged as arm-mcp:latest. The build process takes several minutes as it generates the vector database for the knowledge base.
To verify the image was created successfully:
docker images arm-mcp
The output is similar to:
REPOSITORY TAG IMAGE ID CREATED SIZE
arm-mcp latest a1b2c3d4e5f6 2 minutes ago 1.2GB
Create an isolated Python environment for your test dependencies:
python3 -m venv venv
source venv/bin/activate
On Windows, activate the environment using:
venv\Scripts\activate
The test framework requires Pytest and Testcontainers. Install them using the provided requirements file:
pip install -r mcp-local/tests/requirements.txt
The requirements file includes:
testcontainers
pytest
Run a quick verification to ensure everything is configured correctly:
python -c "from testcontainers.core.container import DockerContainer; print('Testcontainers ready')"
The output confirms Testcontainers can interact with Docker:
The test files are located in mcp-local/tests/:
mcp-local/tests/
├── constants.py # Test data and expected responses
├── requirements.txt # Python dependencies
├── sum_test.s # Sample Arm assembly file for MCA tests
└── test_mcp.py # Main test file
In this section:
In the next section, you’ll run basic Testcontainers examples to understand how containers are managed programmatically.
