Why use GitHub Actions for MCP testing?
GitHub Actions provides automated CI/CD directly in your repository. For MCP server testing, it offers:
  • Arm runner support: GitHub provides native Arm64 runners for building and testing
  • Docker integration: Runners come with Docker pre-installed
  • Automatic triggers: Tests run on every push and pull request
  • Parallel execution: Multiple jobs can run simultaneously
Create the workflow file
Create a GitHub Actions workflow file at .github/workflows/integration-tests.yml:
on:
  push:
  pull_request:
jobs:
  integration-tests:
    runs-on: ubuntu-24.04-arm
    steps:
      - name: Checkout
        uses: actions/checkout@v4
      - name: Set up Python
        uses: actions/setup-python@v5
        with:
          python-version: "3.11"
          cache: pip
      - name: Install test dependencies
        run: |
          python -m pip install --upgrade pip
          pip install -r mcp-local/tests/requirements.txt
      - name: Build MCP Docker image
        run: docker buildx build -f mcp-local/Dockerfile -t arm-mcp .
      - name: Run integration tests
        env:
          MCP_IMAGE: arm-mcp:latest
        run: pytest -v mcp-local/tests/test_mcp.py
Understand the workflow configuration
The workflow uses the ubuntu-24.04-arm runner, which is a GitHub-hosted Arm64 runner. This ensures that both the Docker build and the tests execute natively on Arm hardware.
Key aspects of the configuration:
Trigger events
on:
  push:
  pull_request:
This configuration triggers the workflow on every push to any branch and on pull request events. You can restrict this to specific branches if needed:
on:
  push:
    branches: [main, develop]
  pull_request:
    branches: [main]
Python caching
  with:
    cache: pip
The cache: pip option caches Python packages between runs, significantly speeding up subsequent workflow executions.
Environment variables
  env:
The MCP_IMAGE environment variable tells the test suite which Docker image to use. The test code reads this with:
image = os.getenv("MCP_IMAGE", constants.MCP_DOCKER_IMAGE)
Add test result artifacts
Enhance the workflow to save test results as artifacts for debugging:
        env:
        run: pytest -v mcp-local/tests/test_mcp.py --junitxml=test-results.xml
      - name: Upload test results
        uses: actions/upload-artifact@v4
        if: always()
        with:
          path: test-results.xml
The if: always() condition ensures test results upload even when tests fail.
Add a build matrix for multiple platforms
To test on both Arm64 and x86_64, use a matrix strategy:
jobs:
  integration-tests:
    strategy:
      matrix:
        runner: [ubuntu-24.04-arm, ubuntu-latest]
    runs-on: ${{ matrix.runner }}
    steps:
      # ... same steps as before
This runs the integration tests in parallel on both architectures.
Monitor workflow runs
After you push the workflow file, navigate to the Actions tab in your GitHub repository. Each workflow run shows:
  • Build steps and their status
  • Execution time for each step
  • Log output for debugging failures
  • Artifacts for download
Troubleshoot common issues
If the workflow fails, check these common causes:
Docker build timeout: The initial image build can take more than 10 minutes. GitHub Actions has a default timeout of 360 minutes per job, but individual steps might need explicit timeouts:
  timeout-minutes: 30
Container startup issues: If tests fail with timeout errors, the MCP server might not be starting correctly. Add debug output:
  env:
  run: |
    docker run --rm arm-mcp:latest echo "Container starts successfully"
    pytest -v -s mcp-local/tests/test_mcp.py
Rate limiting: If tests query external services, you might encounter rate limits. Consider adding retry logic or using mock responses for CI environments.
In this Learning Path, you learned how to:
  • Set up Testcontainers for Docker-based integration testing
  • Write pytest tests that communicate with MCP servers over stdio transport
  • Parse MCP JSON-RPC responses and validate tool outputs
  • Configure GitHub Actions with Arm64 runners for automated testing
These techniques apply to any MCP server implementation, not just the Arm MCP Server. Use this foundation to build comprehensive test suites that ensure your MCP tools work correctly across updates and deployments.
