Use the Arm AI Portal’s filters and analytics to compare models. Open a model’s details page to review related content, such as Learning Paths and code examples.
Install the required Python packages, create a Hugging Face access token, and set it in
HF_TOKEN. Use snapshot_download to download the model files, link them from model_dir, and run the supplied ONNX Runtime test script.Update the packages and install Python tooling with
sudo apt update and sudo apt install -y python3-pip python3-venv. The model is optimized for AWS Graviton 4-based Amazon EC2 instances, such as M8g.If the deployment succeeded on a cloud instance, make sure that you’ve enabled access to port
7860. If deployment failed, check the target’s available disk space and confirm that the Docker container is running with docker container ls.Stop the containers that expose port
7860 with docker container stop $(docker container ls --filter expose=7860 -q). You can then deploy another code example that uses the port.
