Open the model on Hugging Face
To open the model on Hugging Face, follow these steps:
  1. On the TinyLlama-1.1B-Chat INT4 model page, scroll to the top and expand Use this Model.
  2. Select Open on Hugging Face.
Note
If you receive a 403 error on the Hugging Face link, you may need to enable two-factor authentication in Settings > Authentication .
You’re now ready to deploy the model. Deployment steps are listed for convenience as follows. For detailed instructions, see How to get started with the model .
Install dependencies
Before you can deploy the TinyLlama model, install its dependencies.
This TinyLlama model is optimized for Arm-based server and cloud CPUs. You can run the following steps on an Arm AGI CPU based on Arm Neoverse V3. You can also use another Arm Neoverse-based server, such as an AWS Graviton 4 instance based on Arm Neoverse V2, which is the model’s reference evaluation platform. Performance will vary depending on the target. Run the following commands on your Arm Linux target:
sudo apt update
sudo apt install -y python3-pip python3-venv
python3 -m venv .venv
source .venv/bin/activate
pip install "onnxruntime>=1.22" "onnxruntime-genai>=0.14" tokenizers jinja2
Visit the Hugging Face access tokens page and create an access token of type Read.
Note
Copy and save the access token immediately after creating it. The token won’t be displayed again after you close the browser or navigate to another window.
Apply the access token to your environment, replacing ACCESS_TOKEN with the token that you generated in Hugging Face:
export HF_TOKEN=ACCESS_TOKEN
echo 'export HF_TOKEN=ACCESS_TOKEN' >> ~/.bashrc   # Optional - if access is desired in future sessions
Download the model
Run the following Python code to download the model:
from huggingface_hub import snapshot_download
local_dir = snapshot_download(
    repo_id="Arm/tinyllama-1-1b-chat-onnx-genai-int4-kquantlast-emb-int8-graviton-g4",
    allow_patterns=[
        "model.onnx",
        "model.onnx.data",
        "genai_config.json",
        "tokenizer.json",
        "tokenizer_config.json",
        "tokenizer.model",
        "special_tokens_map.json",
        "chat_template.jinja",
In your working directory, create a model_dir directory that links to the newly downloaded model:
ln -s ~/.cache/huggingface/hub/models--Arm--tinyllama-1-1b-chat-onnx-genai-int4-kquantlast-emb-int8-graviton-g4/snapshots/$(ls ~/.cache/huggingface/hub/models--Arm--tinyllama-1-1b-chat-onnx-genai-int4-kquantlast-emb-int8-graviton-g4/snapshots) model_dir
If you prefer not to use a link, create a directory named model_dir and move or copy the model files into it.
Test the model with ONNX Runtime
Run the following Python code to load and test the model:
import onnxruntime_genai as og
# Load the model directory (must contain model.onnx + model.onnx.data + genai_config.json + tokenizer)
model = og.Model("./model_dir")
tokenizer = og.Tokenizer(model)
prompt = (
    "<|user|>\nExplain in one paragraph what gravity is and why it matters.</s>\n"
    "<|assistant|>"
input_ids = tokenizer.encode(prompt)
params = og.GeneratorParams(model)
params.set_search_options(max_length=256, do_sample=False, temperature=0.0)
generator = og.Generator(model, params)
generator.append_tokens(input_ids)
while not generator.is_done():
    generator.generate_next_token()
print(tokenizer.decode(generator.get_sequence(0)))
The output is similar to:
 <|user|>
<|assistant|>
Gravity is the force that holds the Earth, moon, and other celestial bodies in orbit around it. It is a fundamental force of nature that is responsible for the movement of objects in the universe. Gravity is a fundamental force of nature that is responsible for the movement of objects in the universe. It is the force that pulls objects towards the Earth, the moon, and other celestial bodies. Gravity is a force that is present in all objects in the universe, regardless of their size, shape, or composition. It is the force that holds the Earth, moon, and other celestial bodies in orbit around it. Gravity is essential for the functioning of the universe, as it is responsible for the movement of objects in space and the formation of planets, stars, and galaxies. Without gravity, the universe would be a chaotic and unstable place, with no order or structure. Gravity is a fundamental force of nature that is essential for the functioning of the universe.
You’ve now successfully downloaded a TinyLlama model from the Arm AI Portal, deployed it on an Arm Linux target, and tested it.
Next, you’ll deploy an ExecuTorch code example from the AI Portal using Topo.
