Give feedback
AI-assisted
Close
How do I know Ollama is ready before running the agent?
Confirm Ollama is running and serving the gemma3:4b model. The local API at http://localhost:11434 should be available before starting the script.
What do I need in the terminal environment when I start the script?
Activate your Python virtual environment and set SERPER_API_KEY in the same terminal session. The agent reads this variable at runtime for web search.
What result should I expect when the agent starts correctly?
You should see a greeting that explains the agent browses websites in real time and a prompt asking for your question. Type quit or exit to end the session.
How do I read the CPU and GPU timeline the agent prints?
CPU entries in the timeline correspond to tools (web search, scraping) and the orchestration pipeline (query expansion, ranking, deduplication, extraction). GPU entries correspond to the Gemma model running through Ollama. The agentic chain interleaves these steps.
Where can I see how the workflow is organized in the code?
Open concierge_agent.py. It groups the tools, the LLM “brain,” the orchestration pipeline, and the agentic chain, and indicates which components run on the CPU or GPU.
