# Understand the CPU's role in the agentic workflow
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/)
- [Understand the agent and how work is split between CPU and GPU](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/1-overview/)
- [Set up your environment before running the agent](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/2-setup/)
- [Serve a model locally with Ollama](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/3-ollama/)
- [Understand the concierge agent code](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/4-code-walkthrough/)
- [Run the agent and read the timeline](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/5-run-and-examples/)
- [Understand the CPU's role in the agentic workflow](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/6-cpu-orchestration/)
- [Next Steps](https://learn.arm.com/learning-paths/cross-platform/ai-agent-cpu-orchestration/_next-steps/)
## How the CPU and GPU share the work
When people picture an AI agent, they usually picture an AI model generating text using just the GPU. In practice, the model is only one stage of an agentic workflow.
The CPU and GPU work in tandem, each handling the part of the workload it does best: the GPU runs the model’s reasoning, while the CPU does the broad, continuous work of orchestration that turns a single request into a useful answer.
## What the CPU does in an agentic workflow
Most agentic systems share the same shape, regardless of the task. Between model calls, the CPU is responsible for the work that surrounds inference:
- Orchestration – deciding what to do next, scheduling tasks, coordinating tools and services, and routing work between multiple AI agents and subagents.
- Tool calls and I/O – calling APIs, querying databases, reading files, and fetching web pages, often many at once.
- Data preparation – cleaning, filtering, ranking, deduplicating, and structuring raw data before it reaches the model.
- Memory and state – tracking conversation history, caching results, and managing context across steps.
These stages are mostly classical computing: concurrency, networking, parsing, and text processing. They run continuously throughout a query, while the GPU is used in focused bursts only when the model reasons. As agents call more tools and handle more data, this CPU-side work grows.
## Why orchestration is a good fit for Arm
This kind of broad, concurrent orchestration and I/O is exactly the workload Arm CPUs handle efficiently. The same pattern scales across Arm platforms:
- On an Apple Silicon MacBook or an Arm Linux laptop, the Arm CPU runs orchestration and I/O while the integrated GPU accelerates the model, so the whole agent runs on one device with no cloud dependency.
- On an NVIDIA DGX Spark, the Arm Grace CPU coordinates the agentic workflow while the Blackwell GPU runs inference, mirroring how larger AI systems are built: CPUs orchestrate, GPUs accelerate.
The key takeaway is that an agent is an *orchestration system*, not just an inference system. The model is one important stage, but the CPU is what turns a single request into tool calls, data, and structured context, and that orchestration is a large part of the work.
## Experiment with updating agent code
To see the effect of the CPU pipeline for yourself, try these changes and compare the timelines:
- Increase the number of query variants in `generate_search_queries()` and watch CPU search time grow.
- Reduce the `max_workers` parameter in `parallel_browse()` to `1` to disable parallel browsing, and see how much longer the CPU I/O stretch becomes.
- Switch to a larger model with `OLLAMA_MODEL=gemma3:27b` and compare how the GPU share changes relative to the CPU share.
Each experiment shifts the balance between CPU and GPU work and makes the orchestration pattern easier to see.
## What you’ve accomplished
You’ve now connected the agent’s timeline to the CPU and GPU work behind each query. You’ve also seen how the number of query variants, the size of the model, and browsing concurrency change that balance.
You can use what you’ve learned in this Learning Path to build your own agentic workflows on Arm for efficient orchestration.
