How the code is organized
The concierge_agent.py script you downloaded earlier is organized into four parts. You’ll understand what runs on the CPU, what runs on the GPU, and how the agent chains them together.
PartResponsibilityRuns on
ToolsWeb search, page scraping, optional emailCPU
The brainCalls the local Gemma model through OllamaGPU
Orchestration pipelineQuery expansion, parallelism, ranking, deduplication, extractionCPU
The agentic chainTies everything together into one query workflowCPU + GPU
The tools
The tools are the agent’s connection to the outside world. search_web() calls the Serper API and returns the top five results. browse_website() downloads a page and strips it down to clean text. Both run entirely on the CPU and both log their activity with log_cpu():
def search_web(query: str) -> str:
    """Use the Serper.dev API to perform a web search."""
    log_cpu(f"Searching web: '{query}'")
def browse_website(url: str) -> str:
    """Scrape and clean the text content of a given URL."""
    log_cpu(f"Browsing website: '{url}'")
    return text[:8000]
browse_website() uses BeautifulSoup to remove <script> and <style> tags, collapse whitespace, and cap the result at 8,000 characters so a single large page can’t dominate the pipeline.
The brain
A single function, call_gemma_ollama(), is the only place the model is used. It sends a prompt to the local Ollama API and streams the response back token by token:
def call_gemma_ollama(prompt, output_format="json", timing=None,
                      label="ollama", timeline_events=None):
    log_gpu("Thinking with local Gemma model...")
    payload = {
        "model": OLLAMA_MODEL,
        "prompt": prompt,
        "stream": True,
        "keep_alive": -1,  # Keep model weights in GPU memory
Two details are worth noting:
  • keep_alive: -1 tells Ollama to keep the model resident in memory between calls. The agent calls the model several times per query, so this avoids reloading the weights each time.
  • The function records timing as it streams. The time until the first token arrives is the model’s input-token processing (prefill); the time spent streaming the rest is token generation. Separating these two values is what lets the agent show you the GPU breakdown later.
Because every model call goes through this one function, the agent only ever uses the GPU in clearly marked places.
The CPU orchestration pipeline
Between the model calls, the CPU prepares the context. Each of the following stages runs entirely on the CPU:
StageFunctionWhat it does
Expand queriesgenerate_search_queries()Turns one query into several variants
Search in parallelparallel_search()Runs all searches concurrently
Browse in parallelparallel_browse()Fetches up to ten websites at once
Rank by relevancerank_and_filter_content()Scores pages with TF-IDF
Deduplicatededuplicate_sentences(), find_near_duplicates()Removes repeated sentences and near-duplicate pages
Extract dataextract_entities()Pulls out phone numbers, hours, and prices
Build indexbuild_keyword_index()Indexes the most frequent terms
The agentic chain
run_concierge_agent() ties the pipeline together. When you read the function from top to bottom, you can see how CPU and GPU steps alternate:
  1. GPU – call_gemma_ollama() turns your question into a search query.
  2. CPU – generate_search_queries() and parallel_search() expand and run the searches.
  3. GPU – the model selects which URLs to open.
  4. CPU – parallel_browse(), rank_and_filter_content(), deduplicate_sentences(), extract_entities(), and the indexing stages prepare the context.
  5. GPU – the model writes the final, fact-checked summary.
You’ve now learned about the structure of the agent code and what functions work on the CPU and the GPU respectively.
Next, you’ll run the agent and watch the CPU and GPU work in real time.
