Modify Learning Path metadata
Each Learning Path contains metadata which is used to create the Learning Path pages. The metadata is used by the website so all Learning Paths have the same information and are consistent.
This section explains how to add Learning Path metadata in the _index.md file:
Metadata and tagging
The following metadata is defined in the _index.md file:
Learning Path MetadataExplanation
titleShould start with a verb (learn, build), have no adjectives (amazing, cool), and be as concise as possible (limit one sentence).
minutes_to_completeTime to perform the steps in the Learning Path (not just read it).
who_is_this_forOne sentence indicating the target audience (developers using tools or software to accomplish tasks).
learning_objectives2-5 bullet points, one sentence each, describing what a reader will learn. Should start with a verb (deploy, measure).
prerequisitesEverything needed before this Learning Path can be started. Can include online service accounts, prior knowledge, previous Learning Paths, or specific tools and software. Offers explanatory links when possible.
authorThe name of the person or people who wrote the Learning Path.
Look at other Learning Paths for inspiration about how to write a good title, learning objectives, and prerequisites.
Note
To specify a prerequisite Learning Path, do so with an absolute path from the root of the website. For example:
Note the absolute path of /learning-paths/cross-platform/docker/
Author information
Adding yourself as an author by populating the author metadata is slightly different if there is one or multiple authors. One author:
author: Zach Lasiuk
Multiple authors:
author:
    - Zach Lasiuk
    - Pareena Verma
In either case, ensure all named authors are listed in the .\assets\contributors.csv file. You must list your name, and optionally include info to display along your name in the Learning Path. This includes your company name, LinkedIn profile, Twitter handle, and your/your company’s website.
Tagging metadata is also expected to increase visibility through filtering. Some tags are closed (you must select from a pre-defined list) and some are open (enter anything). The tags are:
skilllevels (closed)
Indicates the skill level needed as a developer to complete this Learning Path.
OptionExplanation
IntroductoryRequires minimal experience in this field or previous knowledge about the tools/software involved
AdvancedRequires experience with specific topics, tools, or software to properly understand this tutorial
subjects (closed)
Specifies the primary subject the Learning Path covers. Can only be one subject per Learning Path; if it spans multiple, pick the primary one. Select from the allowed list for each category, as defined here:
Embedded and MicrocontrollersIoTServers and Cloud ComputingLaptops and DesktopsMobile, Graphics, and GamingAutomotive
CI-CDCI-CDCI-CDCI-CDCI-CDCI-CD
Performance and ArchitecturePerformance and ArchitecturePerformance and ArchitecturePerformance and ArchitecturePerformance and ArchitecturePerformance and Architecture
MLMLMLMLMLML
Containers and VirtualizationContainers and VirtualizationContainers and VirtualizationContainers and VirtualizationGamingContainers and Virtualization
LibrariesLibrariesLibrariesMigration to ArmLibraries
Virtual HardwareVirtual HardwareStorageGraphics
SecuritySecurityDatabasesAR-VR
Embedded LinuxEmbedded LinuxWeb
RTOS Fundamentals
operatingsystems (closed)
Specifies the operating systems this Learning Path can run on. Select from this list:
OS Options
Linux
Windows
macOS
ChromeOS
iOS
Android
RTOS
Baremetal
tools_software_languages (open)
Specifies the tools, softwares, or languages this Learning Path uses. Please list out any key tools, software, or languages your Learning Path uses.
Tag TypeExamples
EnvironmentsAWS EC2, GCP
ToolchainsGCC, Arm Compiler for Embedded
IDEsArm Development Studio, VS Code
Online ToolsGitHub, Jenkins
Assortedcbuild, Docker
StacktinyML, CMSIS
LanguagePython, Java, Assembly
Librarieszlib, snappy
armips (open)
Specifies the Arm IP this Learning Path involves, providing a quick link to IP information for developers interested in learning more. You can enter multiple specific or groups of IP. Note that this is not used for filtering content, but is clickable for readers to find more information about these IPs through searching automatically on developer.arm.com.
Grouping TypeWhen to useExamples
Specific IPThe Learning Path covers a specific board with one (or a few) Arm IPCortex-M4, Neoverse-N1, Mali-G57
Group of IPThe Learning Path applies to a wider class of Arm IPCortex-M, Cortex-A, Cortex-R, Neoverse, Mali
Further Reading
This is where you provide further reading resources to dive deeper into the topics covered.
Further Reading metadataExplanation
further_readingLinks to references related to information covered
resource > titleThe displayed title of the provided further_reading resource
resource > linkThe website link to the specific resource
resource > typeHelps the reader understand what type of resource is being suggested. Can be either: (1) Manuals for a tool / software (type: documentation). (2) Blog about related topics (type: blog). (3) General online references (type: website).
