Test Learning Paths
This repository provides a framework to help testing instructions, code snippets and maintain content.
The framework allows you to parse Learning Path articles and generate instructions to be run on a Docker container instance. It checks for expected behavior and stores results in Junit XML files. It creates one XML file for each section in a Learning Path.
  1. Install dependencies
  2. Edit Learning Path pages
  3. Edit metadata
  4. Run the framework
  5. Advanced usage for embedded development
The framework is located in the tools folder. From the project root folder, install the Python dependencies with:
pip install -r tools/requirements.txt
Docker is also required. Refer to the Docker Engine install guide to install Docker on Ubuntu.
Bash
Test instructions
Bash instructions can be tested:
    Let's test hello world:
    ```bash
    echo "hello world"
    Or a series or other commands:
    ```bash
    pwd
    echo "hello world"
The framework will check the return code. If not 0, an error will be reported.
Specify expected return code
If a specific return code is expected, it can be specified as follows:
    The file myfile.txt doesn't exist yet
    and this command should return 1:
    ```bash { ret_code="1" }
    test -f myfile.txt
Command output
You can visualize the shell by specifying the command_line option. You can also test for expected output in the instructions by specifying the line(s) where the expected output should be displayed. This is done by adding the pipe symbol (|). Since the first line should contain the command itself, the indexing of the expected output lines starts at 2. You can specify a span (if the expected output is more than one line) with the dash symbol, for example "| 2-10".
    Let's check is this command return the expected output:
    ```bash { command_line="root@localhost | 2" }
    echo "hello world"
    hello world
The code above renders to display the shell identity to the reader:
        echo "hello world"
hello world
The framework will check if the command returns the same output and report an error otherwise.
Context between instruction blocks
The framework understands instructions in the Learning Path share some context, and as such they will be run in order in the same container instance. Files for examples can be created and reused afterwards in the Learning Path:
    Let's create a file:
    ```bash
    echo "Hello world" > myfile.txt
    And check if it exists:
    ```bash
    test -f myfile.txt
It is important to note that the framework does run each code block as a separate terminal session. As such, environment variables do not persist and it assumes the current directory is $HOME. If the current directory needs change, you can specify it as follows:
    Let's create a file in a folder:
    ```bash
    mkdir myfolder
    cd myfolder
    This command will fail:
    ```bash
    test -f myfile.txt
    This command will pass:
    ```bash { cwd="myfolder" }
    test -f myfile.txt
For a command block, it is possible to specify multiple environment variables separated by ;:
    ```bash { env="VAR1=hello;VAR2=world" }
    echo $VAR1 $VAR2
To make environment variables persistent, it is possible to store them in the .bashrc and load them for the command block with env_source:
    ```bash { env_source="~/.bashrc" }
    env
If you want to manage the environment with a tool such as environment modules to load the environment, you can use env_source with pre_cmd which will silently run a command before instructions in the code block:
    ```bash { env_source="/usr/share/modules/init/bash", pre_cmd="module load gcc-12" }
    gcc-12 --version
Ignore instructions
    This console output below will be ignored by the framework:
    ```console
    hello world
Source code
Besides bash instructions, source code can also be tested.
    Here is some C code:
    ```C { file_name="hello.c" }
    #include <stdio.h>
    int main() {
    printf("Hello World\n");
    return 0;
    Let's install GCC:
    sudo apt install -y gcc
    And compile the code with:
    ```bash
    gcc -o hello hello.c
    Run the executable with:
    ```bash
    ./hello
The C code snippet above will be copied over the container in a file named “hello.c”. The other bash command allows to build and run it.
Edit metadata
To allow the framework to parse and test the Learning Path instructions, edit the metadata in _index.md and add the following:
test_maintenance: true
test_images:
- ubuntu:latest
- fedora:latest
The test_maintenance field is a boolean that enables the framework.
The test_images field is a list of Docker container images the framework can pull to test the Learning Path instructions. Check Docker Hub to explore available images.
Run the framework
From the project root folder, run:
./tools/maintenance.py -i content/learning-paths/microcontrollers/my-new-learning-path
If the Learning Path contains sub-articles, the framework will run their instructions in order, depending on the sub-articles weight.
Specify the .md file directly for single file tool install articles.
./tools/maintenance.py -i content/install-guides/mytool.md
If the tests are successful, that will be communicated through the console.
Investigating failures
The framework will print information about any errors to the console. To display additional output, run with the --debug flag.
./tools/maintenance.py -i content/install-guides/mytool.md --debug
Using the Corstone-300 FVP
By default, the framework runs instructions on the Docker images specified by the metadata . For embedded development, it is possible to build software in a container instance and then check its behavior on the Corstone-300 FVP.
For this, all container instances used by the test framework mount a volume in /shared. This is where software for the target FVP can be stored. To check the execution, the FVP commands just need to be identified as a fvp section for the framework.
For example:
    We have previously built software for Corstone-300 in /shared/trusted-firmware-m/cmake_build/bin. To run the software on the FVP:
    ```fvp { fvp_name="FVP_Corstone_SSE-300_Ethos-U55"; cwd="/shared/trusted-firmware-m/cmake_build" }
    FVP_Corstone_SSE-300_Ethos-U55 -a cpu0*="bin/bl2.axf" --data "bin/tfm_s_ns_signed.bin"@0x01000000
The fvp_name allows to specify the FVP to run on. Currently, only FVP_Corstone_SSE-300_Ethos-U55 and FVP_Corstone_SSE-300_Ethos-U65 are supported.
