Inspect runtime events with ETDump
This optional activity records ExecuTorch runtime events on the Raspberry Pi. It uses ExecuTorch Inspector for a tabular profile and Model Explorer for a graph overlay.
ETRecord, ETDump, ExecuTorch Inspector, and Model Explorer
ETRecord is an artifact that can be created when the model is exported. It stores the exported graph, debug handles, and delegate mappings needed to associate runtime events with graph nodes. It does not contain runtime measurements.
ETDump
an ExecuTorch program runs with event tracing enabled. The resulting .etdp
file contains profiling and debugging events recorded by that execution.
ExecuTorch Inspector is a Python API and command-line tool that reads ETDump data. When you also provide the matching ETRecord, Inspector can associate runtime events with operators and delegate metadata from the exported graph.
The ExecuTorch extension for Model Explorer opens the graph stored in an ETRecord and overlays per-node timings from the matching ETDump. The overlay does not currently include delegate timings, so use ExecuTorch Inspector to measure the XNNPACK delegate calls in this activity.
| Artifact | Created | Used in this activity |
.pte | model export | program executed on the Raspberry Pi |
.etrecord | model export | graph context for interpreting runtime events |
.etdp | runtime | events and timings recorded while the .pte runs |
The ETRecord and ETDump must come from the same exported program. Debug handles stored in both files allow Inspector and Model Explorer to associate runtime events with the exported graph.
Create the profiling artifacts
Run on the development machine with .cpu_aot_venv active:
module-2-cnn-inference-with-quantization/scripts/aot/lower_mobilenetv2_xnnpack.py \
--spec module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/model_spec.json \
--profiling-artifacts
In addition to rebuilding mobilenetv2_xnnpack.pte, the script writes:
mobilenetv2_xnnpack.etrecord
mobilenetv2_portable.pte
mobilenetv2_portable.etrecord
Earlier steps did not generate a portable-kernel .pte for MobileNetV2. This script generates one so that you can compare portable and XNNPACK runtime profiles.
From the development machine, copy the .pte files to the Raspberry Pi, substituting your username and IP address into the command:
scp \
module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_xnnpack.pte \
module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_portable.pte \
<user>@<pi>:~/executorch_on_arm/module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/
Build ExecuTorch with event tracing
The prebuilt Python runtime used for the benchmarks does not record ETDump data. Instead you will build ExecuTorch from source with ETDump enabled, using the provided script:
cd ~/executorch_on_arm
source .cpu_lab_venv/bin/activate
sudo apt update
sudo apt install -y cmake ninja-build
module-2-cnn-inference-with-quantization/scripts/pi/build_etdump_runtime.sh
On a Raspberry Pi 5, the first build can take 15–20 minutes and uses roughly 2 GB for the source checkout and build files. Allow at least 3 GB of free disk space.
The script checks out ExecuTorch v1.3.1 to match the course artifacts and
supplies these CMake options to the Python runtime build:
-DEXECUTORCH_BUILD_XNNPACK=ON
-DEXECUTORCH_BUILD_DEVTOOLS=ON
-DEXECUTORCH_ENABLE_EVENT_TRACER=ON
Capture the runtime traces
Run capture_etdump.py once for each artifact. Each invocation performs ten
forward executions and writes one ETDump file, using the same image and
preprocessing as the benchmark:
module-2-cnn-inference-with-quantization/scripts/pi/capture_etdump.py \
--pte module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_xnnpack.pte \
--image module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/sample.jpg \
--runs 10 \
--out module-2-cnn-inference-with-quantization/results/mobilenetv2_xnnpack.etdp
--pte module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_portable.pte \
--runs 10 \
--out module-2-cnn-inference-with-quantization/results/mobilenetv2_portable.etdp
Back on the development machine, copy the traces from the Raspberry Pi, substituting your username and IP address:
mkdir -p module-2-cnn-inference-with-quantization/results
scp \
<user>@<pi>:~/executorch_on_arm/module-2-cnn-inference-with-quantization/results/mobilenetv2_xnnpack.etdp \
<user>@<pi>:~/executorch_on_arm/module-2-cnn-inference-with-quantization/results/mobilenetv2_portable.etdp \
Read delegate timing with Inspector
python -m executorch.devtools.inspector.inspector_cli \
--etdump_path module-2-cnn-inference-with-quantization/results/mobilenetv2_xnnpack.etdp \
--etrecord_path module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_xnnpack.etrecord \
--tsv_path module-2-cnn-inference-with-quantization/results/mobilenetv2_xnnpack_inspector.tsv
Inspector groups the ten runs and reports average, percentile, minimum, and
maximum durations. Look for DELEGATE_CALL with XnnpackBackend in the
delegate column. This row measures the complete delegated region. Backend
events such as XNNPACK convolutions may also appear, but they are not mapped to
individual exported graph nodes in this trace.
Overlay portable operator timings in Model Explorer
Install the Model Explorer profiling packages:
python -m pip install -r module-2-cnn-inference-with-quantization/requirements-model-explorer-profiling.txt
model-explorer \
--port 8081 \
--extensions=etrecord_adapter_model_explorer,etdump_data_provider_model_explorer
Open http://localhost:8081, then open
mobilenetv2_portable.etrecord. In Node data providers, select ETDump
Profiling Overlay, upload mobilenetv2_portable.etdp, and run the provider.
The graph should offer these overlays:
Runtime Total Avg (ms)Runtime Total P50 (ms)Runtime Total Min (ms)Runtime Total Max (ms)Runtime Event Count
The portable trace maps timings to operations such as convolutions and activations.
Stop Model Explorer with Ctrl+C.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
