Inspect the delegation summary
The script walks the lowered graph and counts delegate calls and fallback operations:
graph = edge.exported_program().graph_module.graph
delegate_op = torch.ops.higher_order.executorch_call_delegate
delegate_calls = 0
fallback_targets = []
for node in graph.nodes:
if node.op != "call_function":
continue
if node.target == delegate_op:
delegate_calls += 1
else:
fallback_targets.append(str(node.target))
An executorch_call_delegate node marks a region handled by XNNPACK. Other
call_function nodes remain on the default ExecuTorch path. The counts show
graph fragmentation, but not the amount of computation in each region.
| Artifact | Backend | Precision | .pte size | XNNPACK delegate call sites | Fallback call_function operations |
mobilenetv2_xnnpack.pte | XNNPACK | FP32 | 13.99 MB | 1 | 1 |
One XNNPACK delegate call site means that ExecuTorch will hand one region to
XNNPACK at runtime. In this graph, that region contains the expensive CNN work.
The only remaining call_function operation is <built-in function getitem>.
This operation selects a value from the graph output. It is not part of the main
convolutional workload.
This example provides a good contrast with Module 1. The models have different graph sizes and different operation costs, so the counts are not directly comparable. However, the table below shows that GPT-2 and DistilBERT are split across many delegated and fallback operations, while MobileNetV2 is captured as one large XNNPACK region with one small helper operation left on the default ExecuTorch path. This is because MobileNetV2’s convolution-heavy operators delegate extremely well to XNNPACK.
| Model | Workload | XNNPACK delegate call sites | Fallback call_function operations |
| GPT-2 | Autoregressive transformer decoder | 75 | 746 |
| DistilBERT | Transformer encoder | 27 | 354 |
| MobileNetV2 | Convolutional image classifier | 1 | 1 |
Consider what benchmark result this might lead you to anticipate.
Before moving on, confirm that the lowering step produced:
mobilenetv2_xnnpack.ptemobilenetv2_xnnpack.json
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
