Create the FP32 XNNPACK artifact
Run on the development machine:
module-2-cnn-inference-with-quantization/scripts/aot/lower_mobilenetv2_xnnpack.py \
--spec module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/model_spec.json
The script exports MobileNetV2, lowers supported regions to XNNPACK, prints a
delegation summary, and writes the FP32 .pte artifact and its size metadata.
You should expect to see output similar to this:
Loading MobileNetV2 weights from module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenet_v2.pth...
Exporting MobileNetV2...
Lowering with XNNPACK...
Wrote module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_xnnpack.pte
PTE size: 13.99 MB
Wrote module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_xnnpack.json
Delegation
XNNPACK delegate call sites: 1
Fallback call_function ops: 1
<built-in function getitem> (1)
The generated mobilenetv2_xnnpack.pte is the FP32 ExecuTorch artifact that will run on
the Raspberry Pi.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
