Benchmark the INT8 artifact on Raspberry Pi
On your development machine, copy the new artifact to the Raspberry Pi. Substitute the username and IP address in the following command:
scp module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_int8_xnnpack.pte \
<user>@<pi>:~/executorch_on_arm/module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/
On the Raspberry Pi, and from the repo root, run the benchmark:
module-2-cnn-inference-with-quantization/scripts/pi/benchmark_mobilenetv2.py \
--runtime executorch \
--backend int8_xnnpack \
--spec ~/executorch_on_arm/module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/model_spec.json \
--pte ~/executorch_on_arm/module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/mobilenetv2_int8_xnnpack.pte \
--image ~/executorch_on_arm/module-2-cnn-inference-with-quantization/artifacts/mobilenetv2/sample.jpg \
--runs 50 \
--warmups 10 \
--out ~/executorch_on_arm/module-2-cnn-inference-with-quantization/results/mobilenetv2_int8_xnnpack.json
Quantization changes confidence values and may change
the lower-ranked classes, but you should expect that Labrador retriever and golden retriever remain the leading predictions.
Your latency result will be similar to the following:
| Runtime path | Warm-ups | Runs | Mean | Median | Min | Max |
| INT8 ExecuTorch with XNNPACK | 10 | 50 | 4.01 ms | 3.98 ms | 3.95 ms | 4.56 ms |
Mean latency fell from 10.89 ms for FP32 ExecuTorch with XNNPACK to 4.01 ms for the INT8 path. Relative to the 72.55 ms PyTorch eager reference, the INT8 path was approximately 18.1 times faster in this run.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
