Interpret latency and classification output
Both FP32 tests should identify the image as a Labrador retriever and produce closely matching top-five results. The confidence scores may differ slightly because PyTorch and XNNPACK use different FP32 kernels and may perform operations in a different order. Closely scored lower-ranked labels may also change order. One representative result is:
RankLabelScore
1Labrador retriever63.93%
2golden retriever34.00%
3tennis ball0.36%
4Rhodesian ridgeback0.18%
5Brittany spaniel0.14%
Example latency measurements are:
Runtime pathWarm-upsRunsMeanMedianMinMax
PyTorch eager105072.55 ms72.15 ms71.77 ms76.96 ms
ExecuTorch with XNNPACK105010.89 ms10.88 ms10.73 ms11.63 ms
Your latency measurements and exact confidence scores will differ slightly. In the reference run, both runtime paths produced the same leading classification, confirming that they are processing the input consistently. Mean latency fell from 72.55 ms to 10.89 ms, a speedup of approximately 6.7 times in this test. This timing result is consistent with the delegation report: XNNPACK received the model’s main convolutional workload as one region, allowing for substantial and efficient optimization.
Previous page Complete and continue
