DistilBERT preparation and export
The preparation flow still exports a fixed-shape PyTorch program, but
the wrapper is different from GPT-2. Instead of keeping final-token logits,
it extracts logits at the [MASK] token:
class _MaskLogits(torch.nn.Module):
def __init__(self, model, mask_token_id):
super().__init__()
self.model = model
self.mask_token_id = mask_token_id
def forward(self, input_ids, attention_mask):
# DistilBERT returns [batch, sequence, vocabulary] logits.
logits = self.model(
input_ids=input_ids,
attention_mask=attention_mask,
).logits
mask_positions = (
input_ids == self.mask_token_id
).to(torch.int64).argmax(dim=1)
batch_indices = torch.arange(
input_ids.shape[0],
device=input_ids.device,
return logits[batch_indices, mask_positions, :]
self.model is the original Hugging Face DistilBERT model. mask_positions
contains one token position for each batch item. Pairing it with
batch_indices selects one [MASK] position from each item and returns
[batch, vocabulary] logits.
The input is constrained to one mask token per batch item, so argmax(dim=1)
returns a fixed [batch] position tensor.
The export example prompt must contain the tokenizer’s mask token. In this module, you will keep it to one mask token so the wrapper has a single position to extract:
tokenizer = AutoTokenizer.from_pretrained(args.model_id, use_fast=True)
prompt = args.example_prompt or f"The Raspberry Pi is a {tokenizer.mask_token} computer."
if tokenizer.mask_token not in prompt:
raise ValueError(f"Example prompt must contain {tokenizer.mask_token}")
DistilBERT uses a shorter default sequence length in this module:
parser.add_argument("--seq-len", type=int, default=64)
Run the following command to perform model export on your development machine:
module-1-transformer-inference-with-xnnpack/scripts/aot/prepare_distilbert_fillmask.py \
--out module-1-transformer-inference-with-xnnpack/artifacts/distilbert
This writes distilbert_fillmask_exported.pt2 and model_spec.json. The exported program still takes input_ids and attention_mask, but the output is [B, V] logits for the single mask position rather than next-token logits for a decoder.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
