DistilBERT lowering
The same lowering script as used with GPT-2 is applied here.
Run the following on the development machine:
module-1-transformer-inference-with-xnnpack/scripts/aot/lower_to_executorch.py \
--spec module-1-transformer-inference-with-xnnpack/artifacts/distilbert/model_spec.json \
--backend portable
This creates distilbert_fillmask_portable.pte and distilbert_fillmask_portable.json.
--backend xnnpack
This creates distilbert_fillmask_xnnpack.pte and distilbert_fillmask_xnnpack.json.
Example artifact sizes are recorded below:
| Artifact | Backend | PTE size |
distilbert_fillmask_portable.pte | portable | 268.03 MB |
distilbert_fillmask_xnnpack.pte | XNNPACK | 361.80 MB |
Check deployable artifacts
Before moving on, confirm that the lowering step produced:
- the portable
.pte - the XNNPACK
.pte - the XNNPACK metadata JSON
In the reference run, the XNNPACK artifact is about 94 MB larger than the portable artifact. As with GPT-2, that extra size comes from backend-specific lowered data and metadata stored in the .pte.
The reference XNNPACK run reported:
- XNNPACK delegate call sites: 27
- fallback
call_functionoperators: 354
The fallback list was again dominated by allocation, indexing, shape, mask, and normalization work, including alloc (161), getitem (60), expand_copy (25), and native_layer_norm (14). Mask and elementwise operations such as logical_not, mul.Scalar, scalar_tensor, and where also remained on the default path, along with DistilBERT-specific selection work such as argmax and index.
Compared with GPT-2, DistilBERT produced fewer delegate call sites and fallback operators. Because the graphs differ in size and structure, these counts do not by themselves show better coverage or less fragmentation. Use Model Explorer to inspect the size and placement of the delegated regions. DistilBERT still contains mask handling, reshapes, normalization, and elementwise operations that stay on the default path.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
