Choose a runtime path with PyTorch, ExecuTorch, and XNNPACK
The main question at the outset of this module was “When should you use ExecuTorch instead of the full PyTorch stack on an Arm CPU, and what is the optimal way to do so?"
The following table summarizes likely choices:
| Situation | Likely choice | Why |
| You are developing, debugging, or experimenting on a powerful system | PyTorch | Maximum flexibility and familiar tooling |
| The edge target can support the full PyTorch stack and latency is acceptable | PyTorch may be sufficient | Deployment constraints are not forcing a lighter runtime |
| The edge target cannot support full PyTorch because of footprint or dependencies | ExecuTorch with portable kernels or a supported backend | Smaller runtime and dependency footprint than full PyTorch |
| The target is CPU-only, latency matters, and the model delegates well | ExecuTorch with XNNPACK | Optimized backend kernels can improve supported operations |
| The workload delegates poorly and does not meet a strict latency target | Reconsider the model, backend, or target | Runtime choice cannot rescue a poor model-task-device fit |
PyTorch eager execution is the baseline. If the full PyTorch stack is acceptable on your target and meets the latency target, it may be a reasonable choice.
Portable ExecuTorch kernels provide broad operator coverage and a compact deployment path, but they are not usually the fastest option. They are useful when fitting the full PyTorch stack on the target is the main constraint and functional execution matters more than latency.
XNNPACK performance depends on the work inside its delegated partitions, not only the number of delegate or fallback calls. Large, compute-heavy partitions can provide a substantial benefit. Fallback operators may perform inexpensive allocation, indexing, shape handling, or mask processing, while frequent transitions between delegated and non-delegated execution can add overhead.
Acceptable latency depends on the application and target hardware. Module 2 will show how quantization can further reduce model size and latency.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
