Development machine setup
Start with the AOT flow on the development machine.
If you have not set up your development machine, follow the
Module 1 development machine setup
through creating and activating .cpu_aot_venv, then return here.
If you have not done so already, clone the repository and enter the directory:
git clone https://github.com/ArmDeveloperEcosystem/arm-courses-code-executorch.git ~/executorch_on_arm
cd ~/executorch_on_arm
Use Python 3.12.14, matching Modules 1 and 2. Activate .cpu_aot_venv and
install the pinned Module 3 requirements:
source .cpu_aot_venv/bin/activate
python -m pip install -r module-3-executorch-on-android-semantic-segmentation/requirements.txt
The tested environment uses ExecuTorch 1.3.1, PyTorch 2.12.1, TorchVision
0.27.1, and torchao 0.17.0, which supplies the PT2E quantization APIs used
later in this module.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
