Load the model asset
Android assets are read-only and are not exposed as ordinary filesystem paths.
ExecuTorchSegmenter uses AssetUtils to copy the .pte asset into
app-private storage before loading it:
File modelFile = AssetUtils.copyAssetToFiles(context, MODEL_ASSET);
module = Module.load(modelFile.getAbsolutePath());
Module.load() creates an ExecuTorch Java Module backed by the native
runtime and loads the .pte program from a filesystem path.
Module owns the native runtime state for the loaded program. Labels and
preprocessing settings are application data loaded separately. They are not
interpreted by the ExecuTorch runtime.
Select and decode an image
The Android document picker returns a content URI, an Android reference to
a file supplied by another application or storage provider. MainActivity
opens the URI through ContentResolver, the Android API for accessing content
URIs, and decodes the image into a Bitmap:
Uri uri = data.getData();
try (InputStream stream = getContentResolver().openInputStream(uri)) {
selectedBitmap = BitmapFactory.decodeStream(stream);
A production application should also account for image orientation, large source images, and additional color formats.
Prepare the input tensor
ImagePreprocessor preserves the source aspect ratio, centers the resized
image on a black 520×520 bitmap, and writes normalized RGB values in NCHW order:
float scale = Math.min(
spec.inputWidth / (float) sourceWidth,
spec.inputHeight / (float) sourceHeight
tensor[index] = (red - spec.mean[0]) / spec.std[0];
tensor[pixelsPerChannel + index] = (green - spec.mean[1]) / spec.std[1];
tensor[2 * pixelsPerChannel + index] = (blue - spec.mean[2]) / spec.std[2];
The channel indexing matches the Python preprocessing used for calibration and validation.
Course complete
Nice work
You completed Optimize and deploy AI inference with ExecuTorch on Arm.
